Telemetry Spektrum and Deviation
11 Feb 2017 17:28 - 11 Feb 2017 17:42 #59072 by saidem
Telemetry Spektrum and Deviation was created by saidem
I would like to use RX Spektrum and TM1000 telemetry module. Does it work Deviation transmitters with ?
Thanks.
Last edit: 11 Feb 2017 17:42 by saidem.
12 Feb 2017 01:24 #59085 by Cereal_Killer
Replied by Cereal_Killer on topic Telemetry Spektrum and Deviation
Yes, Spektrum telemetry is supported by the native Devo HF module and is one of the protocols (both RC & telemetry) which doesn't require modding the radio physically!
12 Feb 2017 10:35 - 12 Feb 2017 15:57 #59089 by saidem
Replied by saidem on topic Telemetry Spektrum and Deviation
Thank you for this quick response. I should have read the manual and looked on my radio! But I wanted the expert opinion before buying my receiver.
BTW Spektrum says for the AR9020 receivers that the refresh rate is 11ms instead of 22ms using the DX7se, DX8 or DX10t transmitters. With deviation the rate is it 11ms?
Last edit: 12 Feb 2017 15:57 by saidem.
12 Feb 2017 17:34 #59095 by Cereal_Killer
If you're after telemetry there are several FAR superior options. The two best (frsky s.port and FlySky iBus) do require modules but it's a pretty basic wiring job in most people's experience and the hardware.ini file is dead simple to edit.
12 Feb 2017 19:35 - 13 Feb 2017 08:43 #59097 by saidem
Hello and thank you for your answer.
Do you know if Deviation runs with 11ms or 22ms?
In fact I wanted to take Spektrum because the receivers are very good and some even have the telemetry voltage integrated ex AR9030T.
Could you tell me how to do for FRSKY s.port?
Thanks.
Last edit: 13 Feb 2017 08:43 by saidem.
17 Mar 2017 07:57 #60269 by saidem
Hello Cereal killer
Can you tell me how to set telemetry with your frsky system which I suppose should work with deviation. Is it difficult?
17 Mar 2017 10:05 #60273 by Thomas.Heiss
Replied by Thomas.Heiss on topic Telemetry Spektrum and Deviation
Vlad has added the 11ms speed code enhancement to his "5.0 with latest protocols" Dsmx test build. You can find it in the "build" sub-forum. He uploads compiled zips to the forum. You will NOT find it in the download area.
I could not yet test 11ms it with the AR8000.
There are some Spektrum receivers, which do support 11ms.
17 Mar 2017 14:47 #60280 by saidem
Thank you Thomas for your reply. My receiver is AR9020, so it's an 11mS. Otherwise I went to see the links that Vlad did. Thank you for telling me because I did not know. So I plan on putting on a glider the spektrum telemetry, but the receiver + the TM1000 + the variometer, it starts to make expensive. That's why I asked Cereal. It may be something that would be of interest to other people as well.
Time to create page: 0.689 seconds
