Two models and one radio.
- saidem
06 Mar 2017 18:04 #59912
by saidem
Two models and one radio. was created by saidem
I have two same helicopters with 3GX mrs modules and a radio. Currently I made a template copy. But the problem is that they run together. I would like to know how to make sure they do not work together.
Thank you.
Thank you.
06 Mar 2017 18:34 #59916
Replied by vlad_vy on topic Two models and one radio.
Use different Fixed ID for each heli.
- saidem
06 Mar 2017 19:27 #59924
by saidem
Replied by saidem on topic Two models and one radio.
I did it, but after the rX did not bind anymore. BTW I use a DSMX satellite to run with the Futaba RX . Could you tell me more about fixed ID, and can I use with the DSMX protocol?
07 Mar 2017 04:28 #59938
Yes, it works. But you need rebind the model if you change Fixed ID. Fixed ID combine with transmitter ID to form unique ID for specific model.
- saidem
10 Mar 2017 08:53 #60079
by saidem
I thank you vlad_vy. I re-tried and everything works fine with a fixed ID for each model. I think I had not waited long enough for the bind to happen.
I do not understand exactly how all this works because on page 47 of the manual it is written "If Fixed ID is set None, a transmitter-specific ID is used instead".
I thought that if I did not put a fixed ID automatically, there Would have one generated.
Thank- you for helping-me.
11 Mar 2017 02:24 #60108
Replied by mwm on topic Two models and one radio.
The generated ID for DSM is transmitter-dependent, but not model-dependent. So you really need to set it yourself. I'm not sure why we don't make it model-dependent to prevent that, but we don't.
Different protocols do different thing with IDs, from ignoring them to requiring them, so this answer may not apply to other protocols.
- saidem
15 Mar 2017 16:10 #60221
by saidem
Thank you very much for your reply and for your work.
Time to create page: 0.258 seconds
- Two models and one radio.
