Two models and one radio.
06 Mar 2017 18:04 #59912 by saidem
Two models and one radio. was created by saidem
I have two same helicopters with 3GX mrs modules and a radio. Currently I made a template copy. But the problem is that they run together. I would like to know how to make sure they do not work together.
Thank you.
06 Mar 2017 18:34 #59916 by vlad_vy
Replied by vlad_vy on topic Two models and one radio.
Use different Fixed ID for each heli.
06 Mar 2017 19:27 #59924 by saidem
Replied by saidem on topic Two models and one radio.
I did it, but after the rX did not bind anymore. BTW I use a DSMX satellite to run with the Futaba RX . Could you tell me more about fixed ID, and can I use with the DSMX protocol?
07 Mar 2017 04:28 #59938 by vlad_vy
Yes, it works. But you need rebind the model if you change Fixed ID. Fixed ID combine with transmitter ID to form unique ID for specific model.
10 Mar 2017 08:53 #60079 by saidem
I thank you vlad_vy. I re-tried and everything works fine with a fixed ID for each model. I think I had not waited long enough for the bind to happen.
I do not understand exactly how all this works because on page 47 of the manual it is written "If Fixed ID is set None, a transmitter-specific ID is used instead".
I thought that if I did not put a fixed ID automatically, there Would have one generated.
Thank- you for helping-me.
11 Mar 2017 02:24 #60108 by mwm
Replied by mwm on topic Two models and one radio.
The generated ID for DSM is transmitter-dependent, but not model-dependent. So you really need to set it yourself. I'm not sure why we don't make it model-dependent to prevent that, but we don't.
Different protocols do different thing with IDs, from ignoring them to requiring them, so this answer may not apply to other protocols.
15 Mar 2017 16:10 #60221 by saidem
Thank you very much for your reply and for your work.
Time to create page: 0.112 seconds
