How do i enable headless mode x5sw on a 7e?
18 Mar 2017 05:27 #60309 by blackjackel
How do i enable headless mode x5sw on a 7e? was created by blackjackel
As far as i know the symaX protocol supports headless mode on channel 9
As far as i know the 7e supports only 8 channels...
How would i go about enabling headless mode on x5sw on a 7e? Is there an ini file i can modify? Do i need to download the source to the symaX,mod file, change channel 9 to channel 8 then recompile it?
18 Mar 2017 07:10 - 18 Mar 2017 08:02 #60312 by blackjackel
Replied by blackjackel on topic How do i enable headless mode x5sw on a 7e?
I figured it out on my own, apparently 7e does support 9 channels, you need to update to a nightly build past april 2016
then you need to go to > Model menu > mixer > Scroll down to "Ch9", if it says "none" then choose that then choose "Simple"
Change SRC to HOLD1
Change Curve to Min/Max
Badaboom! done! Now when you flip your left topmost switch your chopper will go in and out of headless mode.
Enjoy
Last edit: 18 Mar 2017 08:02 by blackjackel.
Time to create page: 0.101 seconds
