How to upgrade with Devo 12S
28 Mar 2017 16:59 - 31 Mar 2017 12:26 #60861 by saidem
How to upgrade with Devo 12S was created by saidem
Hello, I installed the file devo12-V5.0.0.dfu, but the file devo-lib. Dfu does not install. I'm not sure if I have the correct version of Dfuse and / or the STM32 driver. Could you help me? Here are the photos.
Attachment not found
thank you very much
Last edit: 31 Mar 2017 12:26 by saidem.
28 Mar 2017 18:47 #60866 by pulpfiction15
Replied by pulpfiction15 on topic How to upgrade with Devo 12S
saidem,
From the pictures you are showing, You try to upgrade a librery dfu.
You should do ths under the librery tab.
29 Mar 2017 07:46 - 29 Mar 2017 08:40 #60894 by saidem
Replied by saidem on topic How to upgrade with Devo 12S
Hello and thank you for taking time to help me.
In fact I think I followed the procedure (see picture below), but there must be something else...
Last edit: 29 Mar 2017 08:40 by saidem.
31 Mar 2017 12:52 - 31 Mar 2017 13:09 #60978 by saidem
Hello
For the passage of my Devo 12S under Deviation, I took the file Devo 12, I think it's OK. I used version 5.0.0 and also a nighty. I replaced my Dfuse version by this one v2.31 - October 6, 2014. I added in my computer the driver STM32 DFU windows 10, but I still have the same problem.
The first dev file upgrade deviation-devo12-v5.0.0 goes well, the second devo12-lib loads, but there is an error message that appears by pressing upgrade. Here are the photos. Do you have any idea what's going wrong?
Here is a photo of the files, do you have the same sizes?
Maybe the file is not good, what do you think?
Last edit: 31 Mar 2017 13:09 by saidem.
31 Mar 2017 13:04 - 31 Mar 2017 13:06 #60979 by vlad_vy
Replied by vlad_vy on topic How to upgrade with Devo 12S
Change program tab to "Library" and Upgrade with "devo12-lib.dfu" file.
Last edit: 31 Mar 2017 13:06 by vlad_vy.
31 Mar 2017 13:20 #60983 by saidem
Ok, I'll try that. I had spent devo 7E and devo 10 and I had never used this command. Must I go back to the 5.0.0 or keep the nighty ..
Thank you for your help, I informed you of the result.
31 Mar 2017 17:01 - 31 Mar 2017 17:04 #60989 by saidem
Thanks vlad_vy, I should have read this a little closer, because it was nevertheless well marked on the manual. But my English is not very good.
I received the 4 in 1 module from Banggood and what's bizarre when I edit the hardware.ini file under notpad ++ I have only one line. I'll make you a copy. And if I copy a good file, it goes back on a single line.
Last edit: 31 Mar 2017 17:04 by saidem.
02 Apr 2017 13:59 #61066 by saidem
Hello pulpfiction15,
In fact I just realized that you also gave me the correct answer that I could not interpret. The famous language barrier. Thank you
10 Apr 2017 16:56 #61344 by saidem
On my devo 12S when I put the current time and date it does not hold when I switch off the transmitter. This always comes back to 2012-01-01. Is this normal?
Thank you for your answers.
10 Apr 2017 17:40 #61352 by FDR
Replied by FDR on topic How to upgrade with Devo 12S
Check the separate button battery for the real time clock in the battery compartment...
11 Apr 2017 10:06 #61376 by saidem
Thanks FDR, so I replaced the battery and now the date and time stay on the screen.
Thank you very much.
23 Apr 2017 18:39 #61710 by saidem
I would like to know if it is normal that the USB drive of the Devo 12S does only 2 MB, because I have only entered very little models and it is already full. The Media file (61 files is 1.51 MB) is it correct? What do I do?
Thank you for your opinion.
23 Apr 2017 18:51 #61711 by FDR
You don't need the media media folder on a 12S, because that is in the library you installed.
24 Apr 2017 13:11 #61729 by saidem
Thanks FDR for helping me, but I should have read the manual a little closer as it was written. So I deleted the Media file and I found a lot of space. The USB drive on the Devo 12S has the same capacity as the Devo 7E (1.97MB) on the Devo 8 it is more important (3.76MB).
Thank you for your help, have good day
25 Apr 2017 18:34 #61773 by saidem
Can I upgrade from version 3.0.0 to 5.0.0 without using version 4.0.0?
Thank you for helping.
25 Apr 2017 18:44 #61774 by FDR
Yes, but check your model configs before use, if they don't have any compatibility issues, because there was a lot changes since 3.0
26 Apr 2017 09:38 #61790 by saidem
Ok, and thanks for your reply. In fact I had put DeViation to a friend TX a few years ago. Now he would like me to put the module 4 in 1. So I think it is imperative to pass his Devo 10 in version 5.0.0 is that right?
25 Mar 2018 16:21 #68347 by christodoulou
Replied by christodoulou on topic How to upgrade with Devo 12S
Hi just upgrade my devo12s from 4.01 to 5 but when i start the tx alot of things that were in old version missing cant change foto fron heli to plane cant find expo&dual cant find alot of things as there is just one pave with 4-5 cattegories.maybe i have done something wrong?also all my models on tx have been deleted...
I just upgrade version 5 then library file then transfer all file in tx root switch on and its so different also no fixed id no bind...i think something is wronv
please help
26 Mar 2018 03:57 - 26 Mar 2018 04:01 #68355 by vlad_vy
You need first backup your model files to PC. Try to download fresh copy of firmware, then "Upgrade" firmware, "Upgrade" library file, then copy all filesystem files to transmitter USB drive.
I don't know what 5.0.0 version do you try to flash, but suggest to use latest build "Deviation v5.0.0 build with latest protocols":
www.deviationtx.com/forum/builds/6407-de...cols?start=380#68343
Don't use devo12-XMS build, it's intended for modded devo12.
If you need some advanced features such as extended audio (voice), try to use nightly builds.
Last edit: 26 Mar 2018 04:01 by vlad_vy.
26 Mar 2018 04:41 #68356 by christodoulou
Thnx for the reply but as there was 2 files version 5 one emu and one other i didnt know from the 2 which one?
There is not any one file says that is for devo 12s just devo 12 :-(
Regarding other features as you said voice and more how i can chose the right one for devo 12 s and not for devo 12?
Also can i bind spektrum/jr receivers with my devo 12s after upgrade?what is the right file to do that and how as i use dfuse usb tool with windows 10
Thnx in advance
Time to create page: 0.889 seconds
