what is going on with my 12s?
26 Apr 2017 11:05 #61793 by Chabaz
what is going on with my 12s? was created by Chabaz
everything was working fine, including the voice alerts, and all of a sudden.... this
i have tried formatting and reinstalling, and still nothing.
any ideas
26 Apr 2017 11:09 #61794 by vlad_vy
Replied by vlad_vy on topic what is going on with my 12s?
Do you try to reflash firmware library file?
26 Apr 2017 11:53 #61795 by Chabaz
Replied by Chabaz on topic what is going on with my 12s?
Yes sir, both the one I had been using previously, and the latest nightly, no luck
04 Jul 2017 22:46 #63297 by Chabaz
A little more information. I have ordered and received the exact replacement LCD module for this 12s I successfully replaced it at which time the transmitter functioned and looked like it should for about 5 minutes. Or to be exact when I put the SD card in the DF player while the transmitter was on. Thinking I must have done this all myself I ordered another LCD module, removed everything having to do with the voice alerts modification replace the LCD once again. Power up the TX everything works and looks as it should for about 5 minutes. I am pulling my hair out what am I missing could it be software-related hardware-related I have looked over the main board under magnification and found no evidence of any failures no shorts xcetera if anybody has any ideas I would love to hear them.
04 Jul 2017 22:49 #63298 by Chabaz
It seems upon the screen failing that it gets progressively worse quite quickly the picture I posted earlier is the first point of failure from there it gets to be completely unintelligible and either turns to a dark multi-colored snow or mostly black with streaks of purple. The to LCD modules that I have put in this transmitter where the exact same part number from a reputable dealer both new modules worked as they should for a few minutes before returning to this failed state. The screen presents this problem when started in dfu or USB mode as well
31 Jul 2017 15:05 #63651 by Chabaz
Replied by Chabaz on topic Will this help solve my issue?
I thought i had it by reloading the firmware, and i did,
at least for 25 min this time.
Configuring models, it started acting wonky again and now is back to the messed up screen,
here is my errors file after the incident,
it was completely blank while it was working as it should.
[Soft fault]
devo12-v5.0.0-1896b91
R0 = 00000000
R1 = 0000012e
R2 = 00000000
R3 = 6c000002
R12 = 2000bda8
LR [R14] (subroutine call return address) = 08005475
PC [R15] (program counter) = 0800542c
PSR = 41000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detec
31 Jul 2017 15:25 #63652 by Chabaz
Replied by Chabaz on topic tried flashing again
and got this
01 Aug 2017 16:11 #63667 by Chabaz
Nobody has any information regarding the error file or the error I'm getting while flashing?
01 Aug 2017 16:21 #63668 by Chabaz
www.deviationtx.com/forum/3-feedback-que...are-errors-txt#23238
This is exactly what my tx is doing. Albeit on a color screen but none the less. This is the font corruption that appears and makes things unreadable
02 Aug 2017 04:16 #63676 by vlad_vy
I think it can be damaged flash memory or any hardware problem related to sound module. If you remove sound module and problem persist, it can be flash memory S29GL128P10TFI01 chip.
02 Aug 2017 04:47 #63678 by Chabaz
Vlad,
Thank you,
Well it's certainly a cheap enough chip that I wouldn't mind replacing it.
I'm not worried about the task itself, but afterwards do you think I would just flash deviation again like normal or I need a different kind of programmer?
There any way to test this chip that you know of?
With the only occurring a few minutes after a full flash that kind of makes sense.
Time to create page: 0.108 seconds
