Devo 10 with Deviation 5.0.0 Throttle Problem
02 May 2017 12:44 #61933 by Fantasmos
After the update my throttle indicates -100% at lowermost position of the stick. I am used to have that set to 0% and full throttle to 100%. Is there anyway I can achieve this result?
02 May 2017 13:53 #61934 by FDR
This is how deviation works, now you have -100...+100 throttle range just like on all the other channels.
However if you want to display a 0...100 throttle range on the main page, you can use a virtual channel for it, which needs 50 as scale and 50 for offset, then use that virtual channel as the source for the main page box.
02 May 2017 13:57 #61935 by Fantasmos
Replied by Fantasmos on topic Devo 10 with Deviation 5.0.0 Throttle Problem
Is it better for me to get used to work with -100 to +100% scale or to make the virtual chanel? Is it like industry standard?
02 May 2017 14:24 #61937 by FDR
I wouldn't call it as industry standard, because there are examples for both ways.
Simply deviation doesn't really distinguish the functions, i.e. there is no dedicated throttle channel in deviation. It is only labeled to match the receiver labels...
Time to create page: 0.106 seconds
