Gain calibration and Brain2
18 Aug 2017 10:32 #63858 by auceto
Gain calibration and Brain2 was created by auceto
Hello guys,
I have a small question about calibrating the tail gain to match the values I need to the Brain value.
I'll explain it better.
For my spirit with Brain2BT fes, I have to set Gain for its tail, but while the Brain range is -100 to +100, Devo's gain channel is from -125 to +125.
I use the DSMX protocol and a complex mixer where I set a fixed curve; So it does not match brain values: for example. If I can set 30 on DEVO Gain the value of the brain is 29.
This is boring and I tried to set min max and scale values on the queue gain channel without results: the curve is always from -125 to +125
How can I set this calibration correctly?
Thanks in advance
Time to create page: 0.098 seconds
