Phoenix Simulator with Devo 7E and 12S
- saidem
11 Jan 2018 17:26 #66864
by saidem
Phoenix Simulator with Devo 7E and 12S was created by saidem
I would like to buy the Phoenix 5.5 simulator for use with Devo 7E and 12S but the seller tells me that it works only with TX 2401,2402,2601,2602,2801.
But I guess it's for TXs that have the original Walkera software. Can you tell me if it works well under Deviation.
Is the dongle supplied compatible with Deviation?
Thank you
Thank you
11 Jan 2018 17:41 #66865
Replied by FDR on topic Phoenix Simulator with Devo 7E and 12S
I would say that if it works with the old Walkera transmitters, then it should work with deviation as well.
- saidem
16 Jan 2018 08:12 #66901
by saidem
Replied by saidem on topic Phoenix Simulator with Devo 7E and 12S
OK, thank you for your answer, I will try.
Time to create page: 0.282 seconds
- Phoenix Simulator with Devo 7E and 12S
