Phoenix Simulator with Devo 7E and 12S
11 Jan 2018 17:26 #66864 by saidem
I would like to buy the Phoenix 5.5 simulator for use with Devo 7E and 12S but the seller tells me that it works only with TX 2401,2402,2601,2602,2801.
But I guess it's for TXs that have the original Walkera software. Can you tell me if it works well under Deviation.
Is the dongle supplied compatible with Deviation?
Thank you
11 Jan 2018 17:41 #66865 by FDR
Replied by FDR on topic Phoenix Simulator with Devo 7E and 12S
I would say that if it works with the old Walkera transmitters, then it should work with deviation as well.
16 Jan 2018 08:12 #66901 by saidem
Replied by saidem on topic Phoenix Simulator with Devo 7E and 12S
OK, thank you for your answer, I will try.
Time to create page: 0.790 seconds
