Something changed...
23 Jan 2018 09:01 #67061
Something changed... was created by vlad_vy
Several days ago something changed at forum. Now I can edit the very last post only, can't delete it, can't edit my old posts. What is the reason? It's inconveniently. If I need to correct something at old post, now I need quote the whole post, write explanation and write all afresh. I can't remove old attachments with comment about removal, and so on.
23 Jan 2018 09:38 #67062
Replied by FDR on topic Something changed...
I will take a look.
The forum is updated regularly whenever there is an update for it, and the settings or their default values might have been changed...
23 Jan 2018 09:47 #67063
Are the Edit and Delete buttons visible for the old posts or not?
BTW the editing is allowed for unlimited time ATM, but I need to check if some other setting could interfere...
23 Jan 2018 09:56 #67064
Can you check if the Edit button is available now for the old posts?
23 Jan 2018 10:10 #67065
Replied by vlad_vy on topic Something changed...
Nothing changed, I can only edit very last message.
- test
23 Jan 2018 11:14 - 23 Jan 2018 11:14 #67068
by test
Replied by test on topic Something changed...
I made you a moderator, which should allow the editing.
Can you check?
Oops, it was me FDR...
Can you check?
Last edit: 23 Jan 2018 11:14 by test.
23 Jan 2018 11:18 - 23 Jan 2018 11:19 #67069
Now I can do even more than I need. I can edit and delete all, my and other's messages. I need to be careful.
Last edit: 23 Jan 2018 11:19 by vlad_vy.
23 Jan 2018 13:54 #67071
Yep, but I trust you!
Actually I could set that everyone can delete their old post anytime, but it seems that the editing is limited for the last post lately...
23 Jan 2018 16:39 #67078
FDR, I have email as moderator from Model configs category. Can you disable emails about new messages for moderators?
23 Jan 2018 16:48 #67080
Probably you rather need to choose where do you want to be a moderator, because now you are a general moderator, but I can limit that for specific forums.
Time to create page: 0.517 seconds
- Something changed...
