Can't use Devo 10 for Velocidrone
- Sebastian
11 Feb 2018 17:24 #67466
by Sebastian
Can't use Devo 10 for Velocidrone was created by Sebastian
Hello everyone,
I just flashed Deviation 5.0 to my Devo 10 and everything went fine. I set USBHID in the model menü and Windows recognizes the transmitter as game controller. When I open velocidrone it recognizes a Deviation Controller, but no input from it. If I remove the controller and try to select a new one, it still doesn't recognize any input from the transmitter and I can't select it. If I quit velocidrone, shut down the Devo and power up it again velocidrone recognizes the transmitter but still no input. Can anyone help?
- MiSKLaCH
13 Feb 2018 11:16 #67486
by MiSKLaCH
Replied by MiSKLaCH on topic Can't use Devo 10 for Velocidrone
I use it with VD without any problem at all, just connect the radio before launching the sim and it should work fine.
Usually once in a while I recalibrate it before using VD, but that doesn't change the way Windows sees it as a joystick device.
I attached my model and icon if needed. Copy rc-sim.ini in the radio attached as USB storage using a free model slot, ex: if you have model 5 free rename rc-sim.ini to model5.ini. I created a custom icon too, just copy rc-sim.bmp file in the modelico folder.
- Sebastian
13 Feb 2018 17:48 #67495
by Sebastian
Replied by Sebastian on topic Can't use Devo 10 for Velocidrone
Support was able to help me. I had to increase the sensitivity to maximum and then after matching the stick movements to actions back to normal. After a short time of no input it won't react until I turn the transmitter off an on again, but not as long as I fly so it doesn't bother me.
Time to create page: 1.090 seconds
- Can't use Devo 10 for Velocidrone
