jjrc jj1000 using v202
17 May 2018 23:59 #69290 by bellegi
jjrc jj1000 using v202 was created by bellegi
Hello, I am new to this and recently purchased a jjrc jj1000 to practice indoor flying with my t8sg jumper. When i bound the jj1000 using the v202 protocol, the drone works but the sticks are reversed. When i use the left stick to move left, the drone goes right and when I use the right stick to yaw right it goes left,etc. Is there a way to reverse the sticks so going left moves the drone left and vice versa? I am almost at the point where I thought i would just swap the motors left and right and wonder if thats what I need to do. Can someone point me in the right direction. Thank you
18 May 2018 06:36 #69292 by 52dgj
Replied by 52dgj on topic jjrc jj1000 using v202
mix→You want the reverse channel→Left frame→reverse
混控→你要反向的通道→左边的框→反向
Time to create page: 0.298 seconds
