DJI ocusync and Deviation (Devo10)
- djar2002
01 Jul 2018 14:59 #69744
by djar2002
DJI ocusync and Deviation (Devo10) was created by djar2002
Hello @all,
the new Ocusync from DJI is a nice system for Racers and it should be compatible with the Devo10 - so i thought. My devo is of course running Deviation, so it is not recognized by the DJI Goggles RE. I figured it is probably a setting of the PPM output via DSC.
Can anybody tell me, what the original Output Data of the Devo10 is? Or what settings I should choose to mimic a standard Devo10?
Thanks in advance!
Thanks in advance!
02 Jul 2018 14:52 - 02 Jul 2018 14:53 #69751
Replied by hexfet on topic DJI ocusync and Deviation (Devo10)
With deviation set the protocol to PPM in the model. You're correct the PPM output is on the trainer port on the tx.
Last edit: 02 Jul 2018 14:53 by hexfet.
- djar2002
02 Jul 2018 16:11 #69753
by djar2002
Replied by djar2002 on topic DJI ocusync and Deviation (Devo10)
Thank you, but I did that. The Goggles just give an error, that this 3rd Brand remote is not supported.
I figured, that the output format is maybe not the same as original firmware, but as the output can be adjusted, maybe I can mimic the original firmware output?
02 Jul 2018 18:43 #69757
Don't know what the original firmware PPM output looks like. Deviation shouldn't be much different as the timing is pretty standard. Maybe the number of enabled channels is different? Does DJI give any info on the acceptable PPM signal? Is it a known good cable to the goggles?
- djar2002
02 Jul 2018 18:46 #69758
by djar2002
It is the cable, DJI provides. Unfortunately, there is no good documentation of the hardware or software by dji.
OpenTX seems to work out of the box. Maybe I'll look up if I can find the standards there.
I'll also check the number of channels later. Could do the trick.
Time to create page: 0.216 seconds
- DJI ocusync and Deviation (Devo10)
