Devo 8S extra switch
- Hoodooguru
30 Jul 2018 07:45 #69991
by Hoodooguru
Devo 8S extra switch was created by Hoodooguru
I want to add a momentary button or switch to my 8S to activate pre launch mode of dlg.
I see the following in the hardware ini:
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
Adding 2 switches is not a problem, so if I edit the above statement to:
extra-switches=2x2
will I be good to go? and if so where can I find a schematic for wiring them up? Have done a search but could not find anything.
John
;extra-switches=
extra-switches=2x2
John
- Hoodooguru
04 Aug 2018 07:52 #70086
by Hoodooguru
Replied by Hoodooguru on topic Devo 8S extra switch
mmmmm
I can only assume that's a big no?
- John A
14 Aug 2018 15:49 #70245
by John A
Replied by John A on topic Devo 8S extra switch
I just went to my local hobby store and bought a momentary switch opened up the radio chose a 2 position switch, un-soldered the wires and soldered them to the new switch, installed the switch. works great for an arm function
- Hoodooguru
15 Aug 2018 00:26 - 15 Aug 2018 01:22 #70250
by Hoodooguru
However, very aware that can be done.
I want to "add an extra" switch, not "replace an existing" switch.
Cheers
John
Cheers
John
Last edit: 15 Aug 2018 01:22 by Hoodooguru.
- Gerry
- Bbrad
15 Aug 2018 06:09 #70251
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Devo 8S extra switch
It can be done using arduino. See this topic
www.deviationtx.com/forum/7-development/...inputs-for-devo-tx-s
- John A
15 Aug 2018 13:24 #70262
by John A
Sorry I misunderstood what you were trying to do.
- Hoodooguru
16 Aug 2018 00:47 #70271
by Hoodooguru
Thanks for the link Gerry, after a quick read that "might" do it. Will be fun to have a tinker with in any case.
I am good to go with arduino, have all the gear and a spare pro mini.
Cheers
John
Gerry wrote: It can be done using arduino. See this topic www.deviationtx.com/forum/7-development/...inputs-for-devo-tx-s
Cheers
John
- Devo 8S extra switch
