Bugs 3 binds to Jumper T8SG throttle not working
13 Aug 2018 16:10 #70233 by bugs3
I applied firmware update to Jumper T8SG to support working with Bugs 3. The Bugs 3 does bind with it but the craft does not respond to throttle input.
Symptoms:
Craft binds and all motor spin up IF throttle it set to midpoint(centered). All motors continue to spin until I drop throttle below midpoint then the motors will stop within a few seconds.
When I increase throttle nothing happens the motor continue to spin at the same RPM.
I have calibrated the sticks several times with no luck
Appreciate any advice I can get resolving this issue.
13 Aug 2018 21:44 #70236 by gdenton
What does the Channel Monitor screen show?
Is the throttle channel transitioning -100 to +100 correctly?
Maybe post the .ini file for us to look at.
14 Aug 2018 15:18 #70244 by bugs3
Yes - The throttle channel positioning is correct -100(min) > 100(max).
I attached the bugs3 model configuration file
16 May 2019 22:45 #74325 by domenic124
Replied by domenic124 on topic Bugs 3 binds to Jumper T8SG throttle not working
hello! I have the same problem after following JayDrone's video with the bugs3mini proto which is on my standard Jumper T8G (bought it this month). I loaded in your model too onto my radio and still no throttle or stick output
Time to create page: 0.778 seconds
