jumper 8 plus vs jumper 12
- rond
07 Nov 2018 15:28 #71613
by rond
jumper 8 plus vs jumper 12 was created by rond
I have a jumper 8 plus and my son is interested in buying the jumper 12, mainly because it is less expensive. What are the differences between the two? Thanks for your help.
- goebish
- NRF Weirdo
07 Nov 2018 16:23 - 07 Nov 2018 17:41 #71615
by goebish
Replied by goebish on topic jumper 8 plus vs jumper 12
The T8 is running Deviation with a built in 4-in-1 transceiver module while the T12 is running OpenTX with an external 4-in-1 module running MULTI.
Also, the T8SG Plus has hall sensor gimbals (better, more durable), while they are potentiometers on the T12, I think that's what explains the price.
Last edit: 07 Nov 2018 17:41 by goebish.
- rond
08 Nov 2018 01:40 #71635
by rond
Replied by rond on topic jumper 8 plus vs jumper 12
thank you, that helps a lot
- ksaves2
11 Nov 2018 18:49 #71721
by ksaves2
Replied by ksaves2 on topic jumper 8 plus vs jumper 12
Pay more and can get a T12 with Hall effect too.
- goebish
- NRF Weirdo
12 Nov 2018 12:07 - 12 Nov 2018 13:12 #71731
by goebish
Yes I suppose they also have the T12 with better gimbals as well.
Then that's up to you to decide if you want to use Deviation or OpenTX + Multi module.
Hint: with Deviation you only have 1 firmware to flash
but even as a DeviationTX contributor I've to admit I love OpenTX on my Taranis ...
Last edit: 12 Nov 2018 13:12 by goebish.
Time to create page: 0.787 seconds
- jumper 8 plus vs jumper 12
