Change 3 in 1 to 4 in 1 module
18 Nov 2018 20:35 #71795 by sv650s
Change 3 in 1 to 4 in 1 module was created by sv650s
I have a 3 in 1 module since many years now in my devo 12S and all works fine.
I will change this module for the 4 in 1 module, for many reasons.
Can I will keep all my models and no bind again each one on the new module ?
Or i will must bind a new time all my models on this new module ?
Thanks for your help.
18 Nov 2018 21:46 #71799 by Fernandez
Replied by Fernandez on topic Change 3 in 1 to 4 in 1 module
No bind,as all is stored in your TX. It is the same chips,just make sure you solder the CSN lines to the same ports. (so same as in hardware.ini)
19 Nov 2018 06:08 #71804 by sv650s
Replied by sv650s on topic Change 3 in 1 to 4 in 1 module
Thanks for your answer.
It's a good news.
19 Nov 2018 09:11 #71805 by goebish
Replied by goebish on topic Change 3 in 1 to 4 in 1 module
You'll have to rebind CYRF6936 protocols.
19 Nov 2018 16:46 #71809 by sv650s
Why i need to rebind CYRF6936 protocols ?
Only this one ?
Thank you.
19 Nov 2018 16:48 #71810 by goebish
Because the internal unique ID of the CYRF6936 is used to compute the TX Id of those protocols (Devo, DSM2 ...).
19 Nov 2018 16:51 - 19 Nov 2018 16:57 #71811 by sv650s
Ok, si i will rebind my models who use cirf6936 protocol.
But, will i need to make again endpoints on esc ?
Last edit: 19 Nov 2018 16:57 by sv650s.
19 Nov 2018 17:29 #71812 by goebish
No, you'll only have to rebind.
20 Nov 2018 17:59 #71829 by sv650s
Ok, thanks for your answer.
23 Nov 2018 15:33 #71857 by sv650s
I have installed the 4 in 1 and i must rebind frsky models to...
23 Nov 2018 15:39 #71858 by goebish
That's weird because frsky protocols use the MCU serial number, which you've not swapped I suppose ;)
12 Mar 2019 05:55 #73311 by backman8571
Replied by backman8571 on topic Change 3 in 1 to 4 in 1 module
Do you have a diagram of where to solder the 4 in 1 module
Time to create page: 0.417 seconds
