Change 3 in 1 to 4 in 1 module
- sv650s
18 Nov 2018 20:35 #71795
by sv650s
Change 3 in 1 to 4 in 1 module was created by sv650s
I have a 3 in 1 module since many years now in my devo 12S and all works fine.
I will change this module for the 4 in 1 module, for many reasons.
Can I will keep all my models and no bind again each one on the new module ?
Or i will must bind a new time all my models on this new module ?
Thanks for your help.
- Fernandez
18 Nov 2018 21:46 #71799
by Fernandez
Replied by Fernandez on topic Change 3 in 1 to 4 in 1 module
No bind,as all is stored in your TX. It is the same chips,just make sure you solder the CSN lines to the same ports. (so same as in hardware.ini)
- sv650s
19 Nov 2018 06:08 #71804
by sv650s
Replied by sv650s on topic Change 3 in 1 to 4 in 1 module
Thanks for your answer.
It's a good news.
It's a good news.
- goebish
- NRF Weirdo
19 Nov 2018 09:11 #71805
by goebish
Replied by goebish on topic Change 3 in 1 to 4 in 1 module
You'll have to rebind CYRF6936 protocols.
- sv650s
19 Nov 2018 16:46 #71809
by sv650s
Why i need to rebind CYRF6936 protocols ?
Only this one ?
Thank you.
Only this one ?
Thank you.
- goebish
- NRF Weirdo
19 Nov 2018 16:48 #71810
by goebish
Because the internal unique ID of the CYRF6936 is used to compute the TX Id of those protocols (Devo, DSM2 ...).
- sv650s
19 Nov 2018 16:51 - 19 Nov 2018 16:57 #71811
by sv650s
Ok, si i will rebind my models who use cirf6936 protocol.
But, will i need to make again endpoints on esc ?
Last edit: 19 Nov 2018 16:57 by sv650s.
- goebish
- NRF Weirdo
19 Nov 2018 17:29 #71812
by goebish
No, you'll only have to rebind.
- sv650s
20 Nov 2018 17:59 #71829
by sv650s
Ok, thanks for your answer.
- sv650s
23 Nov 2018 15:33 #71857
by sv650s
I have installed the 4 in 1 and i must rebind frsky models to...
- goebish
- NRF Weirdo
23 Nov 2018 15:39 #71858
by goebish
That's weird because frsky protocols use the MCU serial number, which you've not swapped I suppose
- backman8571
12 Mar 2019 05:55 #73311
by backman8571
Replied by backman8571 on topic Change 3 in 1 to 4 in 1 module
Do you have a diagram of where to solder the 4 in 1 module
Time to create page: 0.718 seconds
- Change 3 in 1 to 4 in 1 module
