- Setting 3 pos rate switches for t8sg v2 plus
- Mitch
27 Feb 2019 09:20 #73039
by Mitch
Setting 3 pos rate switches for t8sg v2 plus was created by Mitch
Hi guys,
I’m hoping that someone can assist with a proper flow chart on how to set up my brand new MODE 1, jumper t8sg v2 Tx.
I’ve spent over 20 hours, trying to extract from Utube tutorials etc,
Point by point instructions, on how to set up the the 3 position speed rates for the
Ailerons & Elevator, & FLAPS.
I need clear & precise, point by point, instructions on what to enter, to end my frustration, on this particular endeavour.
I’ve already sorted out, KILL/ARMING SWITCH, REVERSING, EPA, RETRACTS, etc
But when Utube tutorials tell you it’s very difficult, & the guys doing these, move their fingers, on the buttons, at LIGHTNING SPEED, it’s nearly impossible to extract anything from the exercise. Hoping somebody can help, so I can get my more complex aircraft flying.
Signing off for now
Signing off for now
- daive
27 Feb 2019 12:27 - 27 Feb 2019 12:41 #73044
by daive
Replied by daive on topic Setting 3 pos rate switches for t8sg v2 plus
Is it like this ?
Main menu -> 1.Model menu -> 2.Mixer -> ▼
Virt6 / Virt10
EX. 3 dual rate , Virt10
<Expo&DR>
Src RUD
High-Rate
< 1-to-1 >
Scale 100
Switch1 SW D1
Mid-Rate ENT 1-to-1
Scale1 75
Switch2 SW D2
Low-Rate ENT 1-to-1
Scale2 50
EX. 3 position switch , Virt6
<Complex>
Mixers : 3
page 1
switch SW A0
Mux replace
Src None
Curve Fixed
Scale 100
page 2
switch SW A1
Mux replace
Src None
Curve Fixed
Scale 0
page 3
switch SW A2
Mux replace
Src None
Curve Fixed
Scale -100
Virt6 / Virt10
<Expo&DR>
Src RUD
High-Rate
< 1-to-1 >
Scale 100
Switch1 SW D1
Mid-Rate ENT 1-to-1
Scale1 75
Switch2 SW D2
Low-Rate ENT 1-to-1
Scale2 50
<Complex>
Mixers : 3
page 1
switch SW A0
Mux replace
Src None
Curve Fixed
Scale 100
page 2
switch SW A1
Mux replace
Src None
Curve Fixed
Scale 0
page 3
switch SW A2
Mux replace
Src None
Curve Fixed
Scale -100
Last edit: 27 Feb 2019 12:41 by daive.
- Mitch
13 Mar 2019 05:43 #73330
by Mitch
Replied by Mitch on topic Setting 3 pos rate switches for t8sg v2 plus
Thanks Daive,
Iv managed to get the 3 position switch working correctly from following a tutorial on Utube.
The program was very similar to yours, except didn’t use th “Vir” trim?
This was a 7 minute clip, & was very well done, so that has solved problem number 1.
Problem number 2.,
Flaps are now controlled by (I’m a Mode 1 flyer)
SW “C”
Pos 1: “CO” : flaps up
Pos 2: “C1” : take off flaps 10-15 degrees
Pos 3: “C2” : landing flaps 45-60 degrees
I wish to Mix down ELEVATOR Trim to FLAP in Position 3: ONLY
I hope some one can help me
Regards from Mitch (The Red Baron) Australia.
Problem number 2.,
SW “C”
- daive
15 Mar 2019 08:39 - 15 Mar 2019 09:02 #73369
by daive
Stick move : -100% ~ 0% ~ 100%
0% is Stick Neutral
Servo degrees ex. 1?: 0 ~ 45 ~ 90 , 0 ~ 90 ~ 180
Servo degrees ex. 2?: -45 ~ 0 ~ 45 , -90 ~ 0 ~ 90
Since i made a sample, please try setting range conversion.
I use Virt 1/2 for explanation and verification.
There are other realization methods, so please try.
What can be done with virtual CH can also be realized with real CH.
Value monitor:Main menu -> 2.Transmitter menu -> 2.Channel monitor : Mixer output ◀ ▶:Stick input
<< EX 1 >>
Vart1 : Complex , Mixers : 3
01. <“C2”& AUX4(44%~60%) : landing flaps 44%-60% , % to digree conversion is required.>
44% , 52% , 60%
45% , 52.5% , 60% : 0.5 , Few can not express
Vart1 page:1 , Switch:SW C2
Mux:replace , Src:AUX4 , Curve:3 Point (ENT) , Point1:44,Point2:52,Point3:60
Scale:100 , Offset:0
02. <“C1”& AUX4( 9%~15%) : take off flaps 9%-15% , % to degree conversion is required.>
9% , 12% , 15%
10% , 12.5% , 15% : 0.5 , Few can not express
Vart1 page:2 , Switch:SW C1
Mux:replace , Src:AUX4 , Curve:3 Point (ENT) , Point1: 9,Point2:12,Point3:15
03. <“CO” : flaps up. >
Vart1 page:3 : Switch:SW C0
Mux:replace , Src:None , Curve:Fixed
Scale : -5%(ex.) , Offset:0
04. < Please check Vart1 : 1-3 mix >
Virt1 - C0 : -5%
- C1 & AUX4 : 9% to 15%
- C2 & AUX4 : 44% to 60%
<< EX 2 >>
Vart2 : Complex , Mixers : 7
01. <“C2”& AUX5(45%~60%) : landing flaps 45%-60% , % to digree conversion is required.>
45% to 60% : Diff 15% , Offset 45%
Vart2 page:1 , Switch:SW C2
Mux:replace , Src:AUX5 , Curve:1 to 1
Scale:50 , Offset:50
Vart2 page:2 , Switch:SW C2
Mux:mult , Src:None , Curve:Fixed
Scale:15 , Offset:0
Vart2 page:3 , Switch:SW C2
Mux:add , Src:None , Curve:Fixed
Scale:45 , Offset:0
02. <“C1”& AUX4( 10%~15%) : take off flaps 10%-15% , % to degree conversion is required.>
10% , 15% : Diff 5% , Offset 10%
Vart2 page:4 , Switch:SW C1
Vart2 page:5 , Switch:SW C1
Scale:5 , Offset:0
Vart2 page:6 , Switch:SW C1
Scale:10 , Offset:0
Vart2 page:7 : Switch:SW C0
04. < Please check Vart2 : 1-3 mix >
Virt2 - C0 : -5%
- C1 & AUX5 : 10% to 15%
- C2 & AUX5 : 45% to 60%
0% is Stick Neutral
<< EX 1 >>
44% , 52% , 60%
9% , 12% , 15%
Virt1 - C0 : -5%
<< EX 2 >>
Scale:15 , Offset:0
Scale:45 , Offset:0
Scale:5 , Offset:0
Scale:10 , Offset:0
Virt2 - C0 : -5%
Last edit: 15 Mar 2019 09:02 by daive.
- Mitch
28 Mar 2019 06:40 #73577
by Mitch
While appreciate you attempt to help me, Surely there should s a MUCH SIMPLER process of mixing a small amount of DOWN ELEVATOR TRIM when switch “C” is switched to position C”2”.
Having to program 20 or more steps to achieve the above, seems like starting all over again.
I never proclaimed to be a computer programmer, much less understand the complex info you sent me, but I am a fairly practical person,
Here’s hoping you can offer a simpler solution.
Kind regards
Mitch TRB
Kind regards
Mitch TRB
- Fernandez
31 Mar 2019 09:50 #73634
by Fernandez
Replied by Fernandez on topic Setting 3 pos rate switches for t8sg v2 plus
This model file I use on my U7E. I use it for a nitro trainer 4ch.
I use a 3 position switch for dual rate. Which give 3 rates high, normal, small. In this file 3pos switch affects the dualrate both for the Ailerons and Elevator travel.
For TS8G, you may need to assign the switch accordingly.
Time to create page: 0.150 seconds
