It dosen't work USBHID by recent nightly build
12 Mar 2019 11:11 #73313 by dheku
Hi.I use i8x-ir8m and T8SG V2 plus.
I updated firmware to recently nightly build.
Problem has occurred so it dosen't work USBHID.
I want to use USBHID.
I want to fix this problem.
Is this bug?
12 Mar 2019 21:41 #73320 by Burntstanding
Replied by Burntstanding on topic It dosen't work USBHID by recent nightly build
I experienced similar on Windows 10. Drivers where coming up with a Migration error. The device is recognized but no stick input. Put the usb into my android phone and it worked fine. I suspected that windows had seen the device previously as a device using one method of USBHid driver and after the firmware upgrade wouldn't see it as a new device but after trying to clear out old registry references I just took the deviation back to 5.0.0 stable.
12 Mar 2019 22:06 #73322 by csujun
I will take a look and get back to you.
13 Mar 2019 15:06 #73334 by dheku
dheku wrote: Hi.I use i8x-ir8m and T8SG V2 plus.
Is this bug?
Whether USBHID works or not,device manager on Windows 10 shows HID compliant game controller and USB input device.
Does that mean that no signal is sent if it is not working?
This is the current state.
Please tell me good advice and idea.
Thank you.
13 Mar 2019 15:26 #73336 by csujun
This is a regression in the new USB code. There is some compatibility problem with USBHID implementation, which works fine on Linux but not on Windows. I am current debug the problem and try to fix it.
04 Apr 2019 22:47 #73694 by dheku
I tried nightly builds deviation-t8sg_v2_plus-v5.0.0-6bfad37 last night.
This problem has fixed.
I am so happy.
Thank you so much.
Have a nice day !
Time to create page: 1.108 seconds
