Rules for model icon
- leloup
09 Sep 2012 22:20 #1439
by leloup
Rules for model icon was created by leloup
What are the rules for create a model icon ? I have try whith 96x96, 16 bits, windows and it's not good... Why ?
09 Sep 2012 23:50 #1441
It should support standard 16bit and 15bit+transparency icons that are 96x96pixels.
I make them in GIMP, I think FDR uses photoshop.
Replied by PhracturedBlue on topic Rules for model icon
Attach an example to a post and I can take a look.leloup wrote: Hi,
10 Sep 2012 08:48 #1462
Replied by FDR on topic Rules for model icon
Make sure you use standard 8.3 names without any special characters...
- kcornels
10 Sep 2012 11:00 - 10 Sep 2012 11:04 #1463
by kcornels
Replied by kcornels on topic Rules for model icon
I've tried to create a Bitmap with PaintShop Pro, but this did not work, I couldn't even open the default buttons with PS. With Gimp it works without problems... .
You have to use 16bit colordepth overall, not 16 bit per channel... . PS can't do this... .
Last edit: 10 Sep 2012 11:04 by kcornels.
10 Sep 2012 11:32 #1465
PS can do it, I've made all my bitmaps with it.
You should edit it in 8 bits/channel RGB, and when saving to BMP format, on the "BMP Options" form click on the "Advanced Modes", then select "A1 R5 G5 B5" or "R5 G6 B5" depending on if you have transparency (with alpha channel).
- magic_marty
10 Sep 2012 17:33 #1470
by magic_marty
would you care to explain how to make them? i have a bitmap i want to try but have no idea on how to get it to work.I downloaded Gimp but don't understand how to use it to make the bitmaps work..
thanks..
Replied by magic_marty on topic Rules for model icon
kcornels wrote: I've tried to create a Bitmap with PaintShop Pro, but this did not work, I couldn't even open the default buttons with PS. With Gimp it works without problems... .
thanks..
10 Sep 2012 18:20 #1472
With Gimp:
Open the bmp by File->Open or draggig it into GIMP (I recommend setting Windows->Single Window Mode in order to make Gimp easier to use)
Then do File->Export To
Open 'Advanced' and set the type to either RGB565 or ARGB1555 depending on if you have transparency or not (both in the 16bit section)
Then save and you are done.
- leloup
10 Sep 2012 19:27 #1477
by leloup
Thanks, it's great. Photoshop is by default on :X1 R5 V5 B5.
Replied by leloup on topic Rules for model icon
FDR wrote: PS can do it, I've made all my bitmaps with it.
Time to create page: 0.214 seconds
- Rules for model icon
