- AUX5 does not calibrate with T8SG V2 Plus and V3
- Ryou
17 Apr 2019 02:09 #73954
by Ryou
AUX5 does not calibrate with T8SG V2 Plus and V3 was created by Ryou
AUX 5 does not store calibration values when performing analog calibration with T8SG V2 Plus. There is no problem with older firmware.
With the new T8SG V2 Plus (V3) carbon color, the 'saving' voice talks twice and says the 'welcome deviation' when the power is turned on.
- Ryou
18 Apr 2019 13:37 #73993
by Ryou
Replied by Ryou on topic AUX5 does not calibrate with T8SG V2 Plus and V3
It was the same with two T8SG V2 Plus carbon patterns.
At power on, we talk that the audio is not relevant twice. The internal PCB has a new audio playback circuit.
Maybe you need some initialization? . Do you need hardware processing? .
- Pao
19 Apr 2019 22:41 - 19 Apr 2019 22:44 #74023
by Pao
Replied by Pao on topic AUX5 does not calibrate with T8SG V2 Plus and V3
AUX5 of my T8SG V2+(carbon) does not work either.
Calibration rewrites < tx.ini > file as below.
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=0
min=0
zero=0
It is a bug of the Deviation.
Hardware is good.
Connect the USB and rewrite < tx.ini > file as below.
[calibrate6]
max=4095
min=0
zero=2047
Now AUX5 works.
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=0
min=0
zero=0
Hardware is good.
[calibrate6]
max=4095
min=0
zero=2047
Now AUX5 works.
Last edit: 19 Apr 2019 22:44 by Pao. Reason: - charactor not see
- Ryou
19 Apr 2019 22:46 #74024
by Ryou
The calibration problem is working in the same way.
Are the audio problems the same? .
When I go into USB mode or DFU mode, I'm nervous.
It becomes a noisy transmitter.
Pao wrote: AUX5 of my T8SG V2+(carbon) does not work either.
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=0
min=0
zero=0
- Pao
20 Apr 2019 01:08 - 20 Apr 2019 01:09 #74025
by Pao
My T8SG V2+ also say "Saving Saving" when turn on it.
and when USB mode or DFU mode keep saying "Saving Saving Saving ..............".
I want it to be quiet quickly.
Last edit: 20 Apr 2019 01:09 by Pao.
- Moeder
20 Apr 2019 20:06 #74041
by Moeder
Replied by Moeder on topic AUX5 does not calibrate with T8SG V2 Plus and V3
Both bugs will be looked into, thanks for reporting.
- Moeder
20 Apr 2019 22:53 #74048
by Moeder
Proposed fix for calibration issue:
github.com/DeviationTX/deviation/pull/862
Has to be tested yet, if you know how to compile deviation yourself please try it out and report back. Otherwise please have a little patience.
- Ryou
22 Apr 2019 11:43 #74081
by Ryou
I confirmed that it works properly.
Thank you.
Thank you.
- Ryou
22 Apr 2019 11:51 #74082
by Ryou
Postscript
The calibration of AUX5 was saved correctly.
The audio problem does not seem to be improved. I do not seem to turn on and make two random utterances.
- 52dgj
22 Apr 2019 12:31 #74084
by 52dgj
Replied by 52dgj on topic AUX5 does not calibrate with T8SG V2 Plus and V3
The F12E and AUX7 built every night also have this problem. Manually modify the tx.ini file to work properly.
- Moeder
22 Apr 2019 19:09 #74091
by Moeder
Should be resolved in nightlies (the calibration issue, not the voice one).
- Moeder
28 Apr 2019 22:50 - 28 Apr 2019 22:50 #74167
by Moeder
As I have no V3 (carbon), I can't look deeply into the voice issue. You could try the attached build (based on current nightly) and see if the issue is fixed. Otherwise I'd suggest removing the mp3 for saving, as there is only really two situations where it should be called in mixer setup.
Last edit: 28 Apr 2019 22:50 by Moeder.
- Ryou
29 Apr 2019 06:24 #74168
by Ryou
Since the correction version of the calibration problem of AUX5, the two random utterances at power on have disappeared.
However, the power on "wellcome deviation" may not come true.
Your 6dfc826 version was the same.
Thank you for your response.
- Moeder
29 Apr 2019 08:26 #74169
by Moeder
Missing welcome message is a known issue. Haven't found a good solution yet. Please try out the build 6dfc826 a little bit, it has reworked voice code. It works fine for me, but another tester would be good to have before pulling in the changes.
- xeutrex
21 Sep 2019 19:26 #75135
by xeutrex
Replied by xeutrex on topic AUX5 does not calibrate with T8SG V2 Plus and V3
For the initial audio repeated I suggest ot refer to this topic:
https://www.deviationtx.com/forum/6-general-discussions/8425-the-voice-on-the-jumper-t8sg-plus-carbon
Time to create page: 0.899 seconds
