Jumper T8SG + set up question
17 Apr 2019 22:56 #73971 by aben
Jumper T8SG + set up question was created by aben
I am trying to change the channel order and add dual rates for a three channel airplane, the Rx is out of a heli and is Flysky protocol, it has a channel order RATE. The protocol on the Tx for Flysky is AETR. I can program in the RATE order into the Jumper OK but when I try to set up the dual rates the Tx changes the channel order back to AETR automatically which does not work. How can I fix this ? I would also like to see if someone can explain how to use the channel reorder screen (9.2.1) in the Jumper manual.
Thanks,
Ben
Time to create page: 0.183 seconds
