Adjustment with PPM Futaba.
- saidem
02 May 2019 16:03 #74191
by saidem
Adjustment with PPM Futaba. was created by saidem
Does anyone know how to set the PPM student to work with a TX Futaba master?
Center PW
Delta PW
Notch PW
Frame Size
Thank you very much for your help.
Center PW
Delta PW
Notch PW
Frame Size
05 May 2019 21:07 #74243
Replied by hexfet on topic Adjustment with PPM Futaba.
The default values should work in almost all cases. Only would need changes if trying to run more than about 8 channels, and in that case Futaba should document the values to use.
- saidem
09 May 2019 16:24 #74263
by saidem
Replied by saidem on topic Adjustment with PPM Futaba.
OK for the answer. I think Futaba has negative polarization PPM as Devention. Do you know if this is true and what happens if you connect 2 different polarizations to each other?
Thank you for your answers.
Time to create page: 0.108 seconds
- Adjustment with PPM Futaba.
