Adjustment with PPM Futaba.
02 May 2019 16:03 #74191 by saidem
Adjustment with PPM Futaba. was created by saidem
Does anyone know how to set the PPM student to work with a TX Futaba master?
Center PW
Delta PW
Notch PW
Frame Size
Thank you very much for your help.
05 May 2019 21:07 #74243 by hexfet
Replied by hexfet on topic Adjustment with PPM Futaba.
The default values should work in almost all cases. Only would need changes if trying to run more than about 8 channels, and in that case Futaba should document the values to use.
09 May 2019 16:24 #74263 by saidem
Replied by saidem on topic Adjustment with PPM Futaba.
OK for the answer. I think Futaba has negative polarization PPM as Devention. Do you know if this is true and what happens if you connect 2 different polarizations to each other?
Thank you for your answers.
Time to create page: 0.118 seconds
