Antenna connection when adding module
- mindo
24 Jul 2019 13:17 - 24 Jul 2019 13:25 #74791
by mindo
Antenna connection when adding module was created by mindo
Hi all,
that's probably obvious but if I use, for example, DSM protocol, could I remove the other antenna attached to CC2500 module or multimodule and viceversa?
Or once I have a module simply connected/enabled, I HAVE TO connect antenna even If I don't use that protocol?
I don't want to burn the tx module....
Fabio
Fabio
Last edit: 24 Jul 2019 13:25 by mindo.
24 Jul 2019 14:51 #74792
Replied by vlad_vy on topic Antenna connection when adding module
If you don't want accidentally burn the module you need to use SMA Terminator 50 Ohm.
- mindo
24 Jul 2019 15:51 #74793
by mindo
Replied by mindo on topic Antenna connection when adding module
Ok! Thanks!
Time to create page: 0.196 seconds
- Antenna connection when adding module
