set the safe value for my throttle to channel 1
13 Aug 2019 23:25 - 13 Aug 2019 23:36 #74870 by superhappyfun
Hi there,
I have a model that uses TAER channel ordering. The default order on a new model was EATR so I went into the reorder menu and swapped T and E. Now whenever I turn on my radio I get a dialog saying...
Ch3: is 0%
safe value = -100%
This is because channel 3 was my throttle channel, but it is now my elevator channel. I can get this to go away by pressing enter or pulling my elevator stick below -100%, but it is very annoying to have to do this. How do I tell the transmitter that the safe value for my throttle should be taken from channel 1, which is my throttle channel. Thanks.
Last edit: 13 Aug 2019 23:36 by superhappyfun.
14 Aug 2019 07:10 #74873 by vlad_vy
Select new model, then select protocol, and channel order will change to protocol specific.
14 Aug 2019 21:53 - 14 Aug 2019 23:53 #74880 by superhappyfun
Replied by superhappyfun on topic set the safe value for my throttle to channel 1
I did this, I selected Frsky as my protocol and it defaulted to AETR. However my quadcopter (an Emax TinyHawk) is TAER.
EDIT:Nevermind, you were correct. It was set to TAER in betaflight which was wrong. I went to the receiver tab in betaflight and switched it to AETR and everything is good! Thanks!
Last edit: 14 Aug 2019 23:53 by superhappyfun.
Time to create page: 0.117 seconds
