t8sg v2 plus carbon - screen very dim
17 Sep 2019 06:54 - 17 Sep 2019 07:46 #75112 by arimasen
t8sg v2 plus carbon - screen very dim was created by arimasen
I just received t8sg v2 plus carbon version but screen is very very dim, it's hard to read anything even in dark room.
The same is with latest firmware.
What can be the reason of this behavior? Is the firmware correct for this because it seems carbon is V3 and firmware is avaliable only for V2.
Please help me.
Thanks in advance.
Regards
Last edit: 17 Sep 2019 07:46 by arimasen.
18 Sep 2019 00:42 #75116 by Ryou
Replied by Ryou on topic t8sg v2 plus carbon - screen very dim
File in transmitter “tx.ini”
brightness = 8
contrast = 8
confirm. If the value is large
Maybe the OLED display is broken.
The same phenomenon when I broke one.
If the inside is not modified, have it replaced at the place of purchase.
I bought a display from Jumper and replaced it myself.
18 Sep 2019 07:27 #75118 by arimasen
Replied by arimasen on topic t8sg v2 plus carbon - screen very dim
I set
brightness = 10
contrast = 10
but the result is the same.
So it seems OLED display is broken...
18 Sep 2019 08:17 #75119 by Ryou
It is also worth checking the cables connected to the OLED screen and the PCB.
09 Feb 2020 06:04 #75903 by steed99
Replied by steed99 on topic t8sg v2 plus carbon - screen very dim
I had same problem when updating latest firmware V2+.. you need to flash with nightly build for V2.. that works..Only because you (we) have the LCD model screen NOT the OLED as advertised, and on SOME v2+ Carbon models as seen on youtubes.... I feel so cheeted!
Time to create page: 0.215 seconds
