- display problem after updating nightly builds
- flyngobanana
05 Dec 2019 05:48 #75521
by flyngobanana
display problem after updating nightly builds was created by flyngobanana
I've got some weird display after updating my Devo 10 from V5.0.0f395b75 to the latest version. Did I miss anything?
05 Dec 2019 06:11 #75522
Replied by vlad_vy on topic display problem after updating nightly builds
Try update transmitter filesystem from firmware archive.
- flyngobanana
05 Dec 2019 06:44 #75523
by flyngobanana
Replied by flyngobanana on topic display problem after updating nightly builds
From which firmware archive?
05 Dec 2019 06:49 - 05 Dec 2019 06:50 #75524
From latest firmware you flashed.
Last edit: 05 Dec 2019 06:50 by vlad_vy.
- flyngobanana
05 Dec 2019 07:40 #75525
by flyngobanana
I tried to reflash the firmware using dfuse but display problem is still here.
Just need to paste filesystem files in USB mode? I'm afraid not to understand exactly what is filesystem.
05 Dec 2019 07:50 #75526
Update transmitter files in USB mode. First, save your model files. Most likely you can also save "tx.ini" and "hardware.ini". Second, update/rewrite all transmitter files. Better will be format the USB drive and write new filesystem from firmware archive. Last, restore saved files.
- flyngobanana
05 Dec 2019 12:04 #75527
by flyngobanana
Thank you. The display is back to normal but I didn't backup "hardware.ini" from my previous version. Most of the protocols names begins with a star so I guess the 4 in 1 module is not enabled anymore. How can I fix it?
The communication between Devo 10 and my computer is very very slow and goes slower and slower like 10mn to copy 562Ko after formating the USB. Shows speed 180 octets/sec, copying one model takes 40 sec.
In attachment is a capture of the files copied on the Devo 10, is there anything missing?
05 Dec 2019 12:43 - 05 Dec 2019 12:46 #75528
1) Missed file "errors.txt".
2) Most likely "hardware.ini" will be (uncomment modules and change ports):
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13
www.deviationtx.com/forum/7-development/...dule?start=960#55157
3) About slow USB drive I don't know, never had such problem. Try to format USB drive at different computer with default options. Or, try different USB cable.
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 05 Dec 2019 12:46 by vlad_vy.
- flyngobanana
05 Dec 2019 14:00 - 05 Dec 2019 14:40 #75529
by flyngobanana
Everything is working now and with some more protocols and RSSI but I found something wrong with ENT button. When I want to create a model name, the enter button either confirm the choice or just move the cursor to the left or confirm and move the cursor to the next letter on the left as well.
Last edit: 05 Dec 2019 14:40 by flyngobanana.
- flyngobanana
06 Dec 2019 05:57 #75532
by flyngobanana
Actually it does the same each time I want to valid my choice with ENT button. If I want to load a model I have to confirm several times before I can access the model list or
If I need to enter into the protocol FrskyX to set RSSI for example , pushing ENT button takes me to the next protocol Frsky-V8, if I valid again with ENT it moves to Frsky.
06 Dec 2019 06:54 #75533
It looks like your ENT button interconnected with L button. Check buttons wiring inside transmitter. You can try any different build to test it, if with different build you get the same problem, it's buttons problem.
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
or
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
or
- flyngobanana
06 Dec 2019 14:18 #75534
by flyngobanana
I flashed it with a previous version that solved everything.
Thanks a lot for your help.
Time to create page: 0.244 seconds
