- t8sg v2 plus Blanc screen after firmware update
- Horacio
06 Dec 2019 20:56 #75536
by Horacio
t8sg v2 plus Blanc screen after firmware update was created by Horacio
Hi all, this is my first transmitter ever, and i had problems with the configuration of the switches. I thought that upgrading the firmware to 2019-12-06 : deviation-t8sg_v2_plus-v5.0.0-83b0755.zip. Now after the upgrade after start up, i get a complete blank screen an a two tone beep.
i tried flashing all the nightly builds in the download list for t8sg v2 plus, but nothing happens.
When flashing to the firmware of the V2: deviation-t8sg_v2-v5.0.0-83b0755.zip its boots up normally.
Hope you guys can help me. i have been waiting two year to get in to the sport so this is frustrating and disappointing.
P.S. Ilive in Suriname south America and the sport is practically non existent here, so i can't get help from locals.
Thanks in advance guys.
- gdenton
06 Dec 2019 21:23 #75537
by gdenton
Replied by gdenton on topic t8sg v2 plus Blanc screen after firmware update
Did you update the transmitter files in USB mode after you flashed the new firmware?
- Horacio
06 Dec 2019 21:45 #75538
by Horacio
Replied by Horacio on topic t8sg v2 plus Blanc screen after firmware update
Yes every time, even formatted a couple of times
- gdenton
06 Dec 2019 22:09 #75539
by gdenton
You might try vlad's builds in the following threads:
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
or
www.deviationtx.com/forum/builds/6407-de...-protocols?start=480
or
07 Dec 2019 07:17 - 07 Dec 2019 07:19 #75540
Replied by vlad_vy on topic t8sg v2 plus Blanc screen after firmware update
I see that your carbon version has LCD screen, not OLED. So, you need to use "t8sg_v2" firmware. The only difference between T8SG V2 and T8SG V2 Plus is used screen.
Last edit: 07 Dec 2019 07:19 by vlad_vy.
- Horacio
07 Dec 2019 10:11 #75541
by Horacio
i think you right, when i taught all v2 plus were oled. let me try again.
- Horacio
07 Dec 2019 10:20 #75542
by Horacio
Vlad you are right about the lcd, flashed the firmware with v2 and all is working okay. tanksvlad_vy wrote: I see that your carbon version has LCD screen, not OLED. So, you need to use "t8sg_v2" firmware. The only difference between T8SG V2 and T8SG V2 Plus is used screen.
- Quemelias
13 Jan 2020 17:18 #75705
by Quemelias
Replied by Quemelias on topic t8sg v2 plus Blanc screen after firmware update
Can you tell me what firmware version do you have? I have a plus carbon and since I update it I see screen mesh. Thanx
14 Jan 2020 12:30 #75713
Do you updated the filesystem? Any font and alignment problems are related to filesystem changes or filesystem damage.
- Quemelias
14 Jan 2020 15:09 #75715
by Quemelias
Could you be more concrete, please? Between being a rookie and from Spain, I get lost sometimes in translation. Thanx
14 Jan 2020 16:15 #75716
Try to renew USB drive filesystem from firmware archive.
- Quemelias
14 Jan 2020 18:30 #75717
by Quemelias
That's why I ask your firmware version, because since I changed it my problems started.
First I use Dfuse to put the file, then change to Usb and place the 11 files. The Dfu and zip file do not include them.
Thank you very much again
- mstansfield001
20 Jan 2020 04:16 #75761
by mstansfield001
Replied by mstansfield001 on topic t8sg v2 plus Blanc screen after firmware update
This just happened to me as well. I just purchased the carbon t8sg v2 plus and updated the firmware using the t8sg v2 plus file. This causes the lcd screen to have black streaks and not usable. I thought I was losing my mind and had bricked the receiver. After finding this post I used the t8sg v2 update file (not plus) and it fixed it.
Deviation dev team please fix the t8sg v2 plus firmware update file to accomodate lcd not oled
many thanks,
-Mike
many thanks,
-Mike
- starleas
20 Jan 2020 07:09 #75762
by starleas
Replied by starleas on topic t8sg v2 plus Blanc screen after firmware update
USB is not recognized.
So I can't reinstall the firmware.
I want to know how to hold the USB driver.
- Quemelias
20 Jan 2020 08:31 #75763
by Quemelias
Please, can you tell me the exact version of the firmware you have used. Thank you!!!
- starleas
20 Jan 2020 08:56 #75767
by starleas
deviation-t8sg_v2_plus-v5.0.0-0c4b4c0 (2020-01-16).zip
- eried
20 Jan 2020 09:17 #75768
by eried
Replied by eried on topic t8sg v2 plus Blanc screen after firmware update
Was the screen like that before the update? that looks like a physical damage but it might be fw.
- Quemelias
20 Jan 2020 09:52 #75769
by Quemelias
Could you send the file you use in your jumper carbon?
According to him you have to use t8sg-V2 firmware, but what version?mstansfield001 wrote: This just happened to me as well. I just purchased the carbon t8sg v2 plus and updated the firmware using the t8sg v2 plus file. This causes the lcd screen to have black streaks and not usable. I thought I was losing my mind and had bricked the receiver. After finding this post I used the t8sg v2 update file (not plus) and it fixed it.
many thanks,
-Mike
- mstansfield001
20 Jan 2020 11:47 - 20 Jan 2020 11:48 #75776
by mstansfield001
Last edit: 20 Jan 2020 11:48 by mstansfield001. Reason: Spelling
- mstansfield001
20 Jan 2020 13:14 - 20 Jan 2020 13:18 #75779
by mstansfield001
@starleas the usb link from the controller is not the same windows driver needed to connect the update tool you show in your screenshot. This video will show you how to fix that.
Also, I would like to thank vlad_vy for originally pointing out our problem. The firmware listed for the t8sg v2 plus was built for oled but we have lcd. Therefore must use the firmware for the t8sg v2 only.
Last edit: 20 Jan 2020 13:18 by mstansfield001. Reason: credit
Time to create page: 0.904 seconds
