Devo 7e problems
- norris
29 Jan 2020 19:03 #75851
by norris
Devo 7e problems was created by norris
Checking via my computer there are models stored on my Devo 7e yet when I turn the transmitter on and go to “load”model menu there’s nothing there, completely blank.
Any ideas?
Thanks.
Any ideas?
Thanks.
- gdenton
30 Jan 2020 01:51 #75854
by gdenton
Replied by gdenton on topic Devo 7e problems
When looking at the 'models' directory on your computer what do you see?
The filenames have to be:
model1.ini
model2.ini
model3.ini
and so on...
model1.ini
model2.ini
model3.ini
and so on...
30 Jan 2020 03:47 #75855
Replied by vlad_vy on topic Devo 7e problems
Uncheck "Hide extensions for known file types" and see if model files have *.ini extension only. Also, model files have to be numbered in series (1..n), without gaps.
- norris
30 Jan 2020 09:27 #75856
by norris
Exactly that with some being renamed with the models that I have downloaded.
Tx memory is completely blank, nothing to select to load.
Replied by norris on topic Devo 7e problems
gdenton wrote: When looking at the 'models' directory on your computer what do you see?
model1.ini
model2.ini
model3.ini
and so on...
30 Jan 2020 10:42 - 30 Jan 2020 10:47 #75857
These files can't be renamed, only "modelN.ini" is acceptable. If system will not find "model1.ini" you will see nothing at list.
Last edit: 30 Jan 2020 10:47 by vlad_vy.
- norris
08 Feb 2020 23:30 #75900
by norris
I have re-flashed the firmware but didn’t get the “Deviation” start up screen on the TX until I formatted the TX drive, if that makes sense?
I then reloaded the drive plus the model file for my V120DO2 and now it seems to be fine.
As yet not flown it but I removed the main blades and spooled it and it seemed to work as it should, well It didn’t go nuts or throw a fit!
However sometimes when you replace the main blades they then go nutty . I have a HCP100S doing that at the moment, don’t know why?
- norris
08 Feb 2020 23:35 #75901
by norris
Does Open TX affect the running of Deviation?
I had to removed various files and programmes ( Open TX being one of them) on my laptop and run maintenance before it worked.
Time to create page: 0.188 seconds
- Devo 7e problems
