t8sg v2 - Windows can't format usb drive
- ramunas
13 Feb 2020 07:29 #75913
by ramunas
t8sg v2 - Windows can't format usb drive was created by ramunas
Is there any utility available to format the usb drive when Windows 10 consistently responds that it cannot proceed with the format request?
I have read the various posts where users have been able to recover from this situation by reloading a new dfu. I have tried all the different varieties of t8sg dfu's with no success. I saw a 2018 post by Vlad_vy that seemed to say that a build is available that may be able to format a usb drive even when widows fails. However that file in that thread has been removed. Vlad or anyone else - I would appreciate knowing if there are any options.
I was able to backup the original files just before the corruption or problem occurred. So finding a way to reformat the usb drive seems to be the only hurdle left. It used the t8sg v2 dfu as one would expect with an lcd screen.
The unit is a new JumperTX T8SG that BG just started selling. It apparently is manufactured by someone other than Jumper.xyz, and uses a mainboard that looks the same as a v2-plus board with an lcd screen. -thanks
13 Feb 2020 07:43 - 13 Feb 2020 08:05 #75914
Replied by vlad_vy on topic t8sg v2 - Windows can't format usb drive
You can try Quick Format option, it's the only working way for nightly build. Also, link to custom build with flash memory bulk erase, but I think it will do nothing if you have damaged filesystem, it can help with inaccessible USB drive:
www.deviationtx.com/forum/6-general-disc...ck-in-usb-mode#71113
Also, you can try to flash build based on v5.0.0, it allow to perform full and quick format:
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
My JumperTX T8SG is on the way.
Last edit: 13 Feb 2020 08:05 by vlad_vy.
13 Feb 2020 07:57 - 23 Mar 2020 14:06 #75915
New T8SG custom builds with "USB drive erase" procedure:
USB drive erase procedure
1) "Power ON" transmitter with USB mode (ENT + Power ON)
2) Press "UP" button
3) After short beep press "DOWN" button
4) After short beep "Power OFF" transmitter
5) "Power ON" transmitter with USB mode (ENT + Power ON)
6) Format transmitter USB drive with Quick Format option enabled
Last edit: 23 Mar 2020 14:06 by vlad_vy.
- ramunas
13 Feb 2020 19:27 #75916
by ramunas
Replied by ramunas on topic t8sg v2 - Windows can't format usb drive
FANTASTIC! Your reformat utility procedure works like a charm, Vlad. - Thanks
14 Feb 2020 07:50 #75919
Added sound indication to buttons press and to be sure you don't "Power OFF" transmitter before erase will complete. The build and description updated.
17 Apr 2020 09:04 - 17 Apr 2020 09:05 #76189
"USB drive erase" procedure added to nightly builds (for devo7e-256, IR8M and T8SG series).
Last edit: 17 Apr 2020 09:05 by vlad_vy.
Builds
- t8sg v2 - Windows can't format usb drive
