t8sg v2 - Windows can't format usb drive
13 Feb 2020 07:29 #75913 by ramunas
Is there any utility available to format the usb drive when Windows 10 consistently responds that it cannot proceed with the format request?
I have read the various posts where users have been able to recover from this situation by reloading a new dfu. I have tried all the different varieties of t8sg dfu's with no success. I saw a 2018 post by Vlad_vy that seemed to say that a build is available that may be able to format a usb drive even when widows fails. However that file in that thread has been removed. Vlad or anyone else - I would appreciate knowing if there are any options.
I was able to backup the original files just before the corruption or problem occurred. So finding a way to reformat the usb drive seems to be the only hurdle left. It used the t8sg v2 dfu as one would expect with an lcd screen.
The unit is a new JumperTX T8SG that BG just started selling. It apparently is manufactured by someone other than Jumper.xyz, and uses a mainboard that looks the same as a v2-plus board with an lcd screen. -thanks
13 Feb 2020 07:43 - 13 Feb 2020 08:05 #75914 by vlad_vy
Replied by vlad_vy on topic t8sg v2 - Windows can't format usb drive
You can try Quick Format option, it's the only working way for nightly build. Also, link to custom build with flash memory bulk erase, but I think it will do nothing if you have damaged filesystem, it can help with inaccessible USB drive:
www.deviationtx.com/forum/6-general-disc...ck-in-usb-mode#71113
Also, you can try to flash build based on v5.0.0, it allow to perform full and quick format:
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
My JumperTX T8SG is on the way.
Last edit: 13 Feb 2020 08:05 by vlad_vy.
13 Feb 2020 07:57 - 23 Mar 2020 14:06 #75915 by vlad_vy
New T8SG custom builds with "USB drive erase" procedure:
USB drive erase procedure
1) "Power ON" transmitter with USB mode (ENT + Power ON)
2) Press "UP" button
3) After short beep press "DOWN" button
4) After short beep "Power OFF" transmitter
5) "Power ON" transmitter with USB mode (ENT + Power ON)
6) Format transmitter USB drive with Quick Format option enabled
File Attachment:
File Name: deviation-...3-23.zip
File Size:684 KB
File Attachment:
File Size:684 KB
File Attachment:
File Size:684 KB
Last edit: 23 Mar 2020 14:06 by vlad_vy.
13 Feb 2020 19:27 #75916 by ramunas
Replied by ramunas on topic t8sg v2 - Windows can't format usb drive
FANTASTIC! Your reformat utility procedure works like a charm, Vlad. - Thanks
14 Feb 2020 07:50 #75919 by vlad_vy
Added sound indication to buttons press and to be sure you don't "Power OFF" transmitter before erase will complete. The build and description updated.
17 Apr 2020 09:04 - 17 Apr 2020 09:05 #76189 by vlad_vy
"USB drive erase" procedure added to nightly builds (for devo7e-256, IR8M and T8SG series).
Last edit: 17 Apr 2020 09:05 by vlad_vy.
Time to create page: 0.044 seconds
