Cloned repository changes
17 Sep 2012 11:56 - 17 Sep 2012 12:27 #1675 by FDR
Cloned repository changes was created by FDR
@PB
How to sign, if somebody has a change in his cloned repository, which you should merge into yours? (i.e. how to do pull requests for such, because bitbucket doesn't allow me to do so)
I have to merge every change of yours lately, because mine changes are not merged back...
Or should we treat for example the language changes otherwise? I mean should I always post the corrected language file instead of pushing it to my repo?
Last edit: 17 Sep 2012 12:27 by FDR.
17 Sep 2012 12:33 #1677 by PhracturedBlue
Replied by PhracturedBlue on topic Cloned repository changes
FDR wrote: @PB
The easiest way to do it is to fork my repository from bitbucket. either discard your current repo, or create another with a different name.
in bitbucket, go to my repo, and then select 'fork'
you can now check out your new repository and make changes and check in as usual (you probably want to copy the .hgrc file from your current repo into the new one to make syncing easier)
Anyhow, now you can generate pull requests from bitbucket
17 Sep 2012 12:44 #1678 by FDR
Replied by FDR on topic Cloned repository changes
OK, I'll give it a try...
If you could solve the gcc version problem too... ;)
17 Sep 2012 16:19 #1684 by PhracturedBlue
Hopefully it will work for you now.
17 Sep 2012 18:35 #1686 by FDR
Yep, it compiles now...
17 Sep 2012 19:09 #1690 by FDR
I was able to send a pull request too...
Will it do this way?
17 Sep 2012 19:14 #1691 by PhracturedBlue
FDR wrote: I was able to send a pull request too...
Yes that worked quite well. I can just click a button to accept your pull.
Time to create page: 0.480 seconds
