version 1.1.1 giving me a blank screen!
- magic_marty
18 Sep 2012 05:05 #1703
by magic_marty
version 1.1.1 giving me a blank screen! was created by magic_marty
when i try updating to the latest version i have to try several times to get it to load and after it does and i leave dfu mode my screen is blank..i can go back to the 1.1.0 version and its fine but the 1.1.1 version for some reason is not working for me...any ideas on what i might be doing wrong? or any ideas on what i should try?
thanks a bunch...
thanks a bunch...
18 Sep 2012 05:09 #1704
Replied by vlad_vy on topic version 1.1.1 giving me a blank screen!
- magic_marty
18 Sep 2012 05:13 #1705
by magic_marty
Replied by magic_marty on topic version 1.1.1 giving me a blank screen!
no i didn't do the file system yet...should i do the file system first?
18 Sep 2012 05:16 - 18 Sep 2012 05:17 #1706
All info about update from previous version described at Release Notes v1.10. Do NOT copy the 'models' directory. If you do, you'll lose all of your saved models!
Last edit: 18 Sep 2012 05:17 by vlad_vy.
- magic_marty
18 Sep 2012 05:20 #1707
by magic_marty
i did the file system and its still giving me a blank screen when i leave the dfu after upgrade to the 1.1.1
i copied the models to but i saved a back up of my models on my laptop...
18 Sep 2012 05:27 - 18 Sep 2012 05:28 #1708
Replied by FDR on topic version 1.1.1 giving me a blank screen!
My own 1.1.1 build works for me, but I cannot try the posted dfu at the moment.
Try to download it again, may be the file is corrupted...
(EDIT: it should not be, because there is a CRC check in it, but still worth a try)
Last edit: 18 Sep 2012 05:28 by FDR.
- magic_marty
18 Sep 2012 05:30 #1709
by magic_marty
ok i'll try redownloading and give it another try...
- magic_marty
18 Sep 2012 05:33 #1710
by magic_marty
says my download limit has been reached...i only downloaded it once earlier..guess i'll have to wait
18 Sep 2012 05:34 - 18 Sep 2012 05:38 #1711
Something going wrong. Try formating the file system and do new copy of file system.
Shutdown Tx, press 'Ent' button and switch on Tx. Next, open the 'Removable Drive' in Windows explorer, format the 'Removable drive' and copy file system. Do not copy the 'filesystem' directory itself.
Last edit: 18 Sep 2012 05:38 by vlad_vy.
- magic_marty
18 Sep 2012 05:39 #1712
by magic_marty
i get this error code when trying to upgrade to 1.1.1
Error Code:Bad state machine in firmware!
- magic_marty
18 Sep 2012 05:41 #1713
by magic_marty
tried the upgrade again after the error and it upgraded but after leaving the dfu mode the screen is blank and i have to unplug the battery to get the tx to turn off...this is after i formated the file system...currently there is no file system on the tx...
- magic_marty
18 Sep 2012 05:54 #1714
by magic_marty
ok here is what i did....
1 formated the drive and loaded the 1.1.1 file system
then i powered off and powered back on in update mode i used the dfsu tool to upgrade to the 1.1.1 firmware and when i clicked "leave dfu mode" the screen flickers and goes blank and i can't power off unless i unplug the battery...so i unplug the battery the turn back on in dfu upgrade mode and use the dfsu tool to put the 1.1.0 firmware back and the tx works again...
- magic_marty
18 Sep 2012 06:03 #1715
by magic_marty
i downloaded the 1.1.1 dfu again and tried upgrading and it does the same thing...blank screen
18 Sep 2012 06:06 #1716
Has anybody else tried?
18 Sep 2012 13:12 - 18 Sep 2012 13:13 #1719
This download menus software is making me unhappy. I think I fixed this for real this time, but the zip file wouldn't uncompress if the file was corrupted, so that isn't it.
can you press-hold ENT while bootup? Does it show 'Entering USB mode' (or whatever), and does it connect to your PC?
Strictly speaking you don't need the new filesystem for 1.1.1 teh only changes are to the model.ini files which you probably don't want.
Replied by PhracturedBlue on topic version 1.1.1 giving me a blank screen!
I thought I fixed that.magic_marty wrote: says my download limit has been reached...i only downloaded it once earlier..guess i'll have to wait
Last edit: 18 Sep 2012 13:13 by PhracturedBlue.
18 Sep 2012 13:19 #1720
I've confirmed that 1.1.1 is broken on the Devo8 though it works fine on the Devo6. This is the 1st time I've seen this issue, builds are generally very reliable for me.
I've removed 1.1.1 until I figure out what is going on.
18 Sep 2012 13:30 #1721
Further testing shows that 1.1.1 is a complete dud. I'll have to figure out what I broke, but that will take time and I don't have it right now. sorry about that.
- magic_marty
18 Sep 2012 16:26 #1726
by magic_marty
no worries...i was just thinking i was doing something wrong but as you confirmed its the 1.1.1 dfu...
thanks a bunch..
thanks a bunch..
19 Sep 2012 02:25 #1732
1.1.2 is up and should be working. I tested both the devo6 and devo8 dfus successfully.
- magic_marty
19 Sep 2012 05:11 #1738
by magic_marty
Thanks a bunch...i upgraded to the 1.1.2 and it works well...i had to reboot my laptop cause the crazy walkera dfsu tool kept crashing and giving bad sector errors but after a reboot it installed first try...
thanks again to everybody for all the hard work and for sharing this incrediable firmware its the greatest !!
Time to create page: 1.890 seconds
- version 1.1.1 giving me a blank screen!
