Devo 10 Deviation v5.0.0 GUI on RC size
- Wilcox
01 Jul 2020 09:39 #76547
by Wilcox
Devo 10 Deviation v5.0.0 GUI on RC size was created by Wilcox
Good day everyone.
I have a Devo 10 and have v4.0.1 firmware on the Controller and it works fine.
I used the DFuse tool on Windows 10 to upload Deviation v5.0.0 and once complete and disconnected from the computer, when I turn the Devo 10 on the GUI screen seems out of scale. I cannot see the menu when I open it and all the lines of text on the main screen are bunched up. Its like the GUI is using the wrong scale to display the pages.
I tried to look through the various .INI files to see if there was an issue but I dont know where to begin to resolve this.
I reinstalled V4.0.1 and it works just fine and the GUI is back to normal.
Does anyone perhaps have a solution?
01 Jul 2020 13:09 - 01 Jul 2020 13:11 #76552
Replied by vlad_vy on topic Devo 10 Deviation v5.0.0 GUI on RC size
You need renew transmitter filesystem also. Backup used model files, erase old filesystem, write new filesystem from firmware archive, setup and calibrate transmitter, return model files. Use Safely Remove Hardware after any write to transmitter filesystem.
Last edit: 01 Jul 2020 13:11 by vlad_vy.
- Wilcox
01 Jul 2020 14:13 #76553
by Wilcox
Replied by Wilcox on topic Devo 10 Deviation v5.0.0 GUI on RC size
Thank you.
So I Deleted all the old files after backing up my models.
I used DFUSe and updated Firmaware to 5.0.0. Ejected hardware.
Copied the files(Language, Modelico,Model etc) to the Devo transmitter)
Turned on the Devo again after ejecting and the LCD screen still does the same thing.
The Deviation splash screen looks too big. the menu page when selected only shows the word menu and no other options.
I reinstalled v4.0.0.1 and it goes back to working
02 Jul 2020 05:25 #76554
I'm not sure, you copy to transmitter USB drive new filesystem (files) from firmware archive or from your old backup? From old backup you need return used model files only.
- Gerry
- Bbrad
02 Jul 2020 05:56 #76555
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Devo 10 Deviation v5.0.0 GUI on RC size
Which Dfuse? v2.31?
only thing i do that vlad_vy hasn't already said is I tend to do a format before copy new file system
- Wilcox
02 Jul 2020 07:08 #76556
by Wilcox
After updating the V 5.0.0 Firmware and ejecting, I connect in USB mode. I copy the files from the Unzipped V5.0.0 folder ( except for the models folder that is from my backup)
I am using DFuse 2.31.
I will try a format as Gerry suggests. I read another post about an LCD init issue. Could it be related to that?
- Wilcox
02 Jul 2020 07:11 #76557
by Wilcox
I took a video of of what happen after the update to show what the LCD shows and how the GUI is affected. Could I mail it to you to see?
02 Jul 2020 07:26 #76558
What v5.0.0 do you use? Nightly builds or anything else?
Try different build based on v5.0.0 release:
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
- Wilcox
02 Jul 2020 07:28 #76559
by Wilcox
I dont use the nightly build. Just proper v5.0.0 for Devo 10
- Wilcox
02 Jul 2020 07:29 #76560
by Wilcox
I will try the different build you suggest.
- Mack775
03 Jul 2020 00:35 #76562
by Mack775
Replied by Mack775 on topic Devo 10 Deviation v5.0.0 GUI on RC size
I have used those bilds on 5 devo 10 s and no problem. Just rember to use safely remove from usb.
Have Fun Mack
Have Fun Mack
- Wilcox
10 Jul 2020 11:26 #76576
by Wilcox
Hi Vlad.
I tried to use the different build but it still makes the GUI on the menu the wrong scale so I am not able to see the transmitter menu.
To format the devo 10, do I just format it via Windows after I back the models up? Is there any particulare partitioning I must use? Like FAT32? Or just a regular "Right Click" Format drive?
10 Jul 2020 11:54 #76577
Use a regular "Right Click" Format drive. Select "Quick Format" option.
- Wilcox
10 Jul 2020 14:56 #76579
by Wilcox
Thank you.
I did the format.
Installed the V5 Nightly build.
Copied over the new library from the nightly build folder as well as my model backup.
The issue still occurs.
I reinstalled V4.0.1 and it works normally.
I really dont know what to make of this
I did the format.
- Mack775
11 Jul 2020 14:02 #76580
by Mack775
Have you tried with out copping backup over?
- Wilcox
11 Jul 2020 18:17 #76581
by Wilcox
Hi Mack.
Yes I have tried that as well.
I will just use V4.0.1. At least I can see the menu and navigate the GUI on theDevo 10 with it.
- Mack775
11 Jul 2020 19:27 #76582
by Mack775
I can't understand what is going on. I do the flashing for this area and never had any trouble with the devo 10. Messed up devo.fs on devo F7 once and GUI was messed up but never on devo 10. Had to reinstall devention and start over to get it to work. They are some very nice people on this forum, I bet someone has an idea. Good luck Mack
Time to create page: 0.050 seconds
- Devo 10 Deviation v5.0.0 GUI on RC size
