- Are you sure about walkera 2601 protocol ?
- leloup
23 Sep 2012 20:43 #1765
by leloup
Are you sure about walkera 2601 protocol ? was created by leloup
I try desperately to run my 4G6S with my hacked devo 8s. In 2601 protocol, if i try 120 ° swashplate, nothing is normal. Rudder is good but that's all ! Throttle is mixed by throttle stick and left position of ail. stick !
Anyone tried this protocol ?
- magic_marty
23 Sep 2012 23:24 #1766
by magic_marty
Replied by magic_marty on topic Are you sure about walkera 2601 protocol ?
i just use the 2801 protocal on my 6ch rx's and it works fine..check to see if you have the stick mode set to how you fly..also on the swash page you can reverse the ele/ail channels i had to reverse the ele on my hm1a when i set it up...
- leloup
24 Sep 2012 05:42 #1769
by leloup
Replied by leloup on topic Are you sure about walkera 2601 protocol ?
The rx2610v don t accept 2801 protocol. I have tried all solutions...
24 Sep 2012 07:21 #1770
Replied by vlad_vy on topic Are you sure about walkera 2601 protocol ?
Setup for the Walkera 4G6V Helicopter - RX2610V2 Receiver with 3-Axis Gyro
helifreak.com/showpost.php?p=3796656&postcount=7
- leloup
24 Sep 2012 08:30 - 24 Sep 2012 08:33 #1772
by leloup
Thanx, but the 2610s is in 3 servo mode not like the 2610V (1 servo because the mix is doing by the rx).
Normally, the 6ch heli template is good for the 4G6S but don't work...
Last edit: 24 Sep 2012 08:33 by leloup.
- magic_marty
24 Sep 2012 16:17 #1774
by magic_marty
did you try setting the swash to "none" ? usually it works on 3axis rx's ..
- leloup
24 Sep 2012 19:09 #1776
by leloup
Yes, i have try all swash config, the servo reaction is totally aberrant...
24 Sep 2012 19:30 #1783
Replied by FDR on topic Are you sure about walkera 2601 protocol ?
Please describe the problem a bit more!
First you should make sure there is no CCPM in the rx, so use a simple 4ch template (or the default state) to see if you move one channel (for example the elevator), the two other servos don't move. (If they do, you don't need the CCPM in the tx, so use my 6ch heli template posted here instead...)
If they don't move, than load the 6ch CCPM heli template, set the swash type to the appropriate one (can you check what swash type did you use in your 2602/2801?).
Now see which servo does what, when you move the elevator?
Which is doing good, which is not?
Or try the pitch: all of them should move in one direction. If not, some should be reversed.
- leloup
24 Sep 2012 19:58 #1785
by leloup
In the 2801, i'm in 3 servo 120° swash type so :
With a 6ch simple config i have this :
Ele -> Ele only
Ail -> Ail only
Thr -> Thr + Negative pitch servo
Rud -> Rud only
Gear -> nothing
Ch6 -> Thr + Positive pitch servo
When i say that's not normal...
Ele -> Ele only
Ail -> Ail only
Rud -> Rud only
Gear -> nothing
24 Sep 2012 20:14 #1786
I cannot try it on a real heli, because I have only a FBL one, which needs 1 servo (normal) swash type, but I've just tried in the emulator, and with the 6ch heli template and 120° swash both 2601 and 2801 protocols behaved as expected...
- leloup
24 Sep 2012 20:27 #1787
by leloup
That's why i'm looking another 2601 protocol user...
I think 2601 protocol is not a normal 1ch to 1ch protocol.
- flyguy
28 Sep 2012 23:28 #1860
by flyguy
Replied by flyguy on topic Are you sure about walkera 2601 protocol ?
i just received my Devo 8S today. I bought it, because i read it can be modified. so here i am
i also have a 4g6s with a rx2610s-1 receiver and i think i got it running, but i have a problem with one of the servos, it does not move correctly, but i'm not sure, if it's a hardware problem or not.
so, i will attach my current config, it should also work for you. i couldn't really test it, but the servos move correctly. maybe there is reverse needed on the rudder.
please tell me, if it works for you, especially if the right servo behaves somehow strange.
- leloup
29 Sep 2012 11:39 #1866
by leloup
hi
i have tested your model config. I have a problem on the pitch servo, when the throttle stick is near the middle position, the pitch servo is doing a small jump.
And i have no throttle on this config, i think it's about the safety value.
- flyguy
29 Sep 2012 18:27 - 29 Sep 2012 18:28 #1871
by flyguy
that "servo jump" is my problem as well. so it could be some protocol problem. i also tried with a different servo and have exactly the same issues.
i also can confirm your "no throttle" problem. i didn't test the throttle yesterday, but it seemed fine (checked via channel monitor).
i tested some more right now and it seems that something is messed up with the channel mapping. cyclic 3 should be on channel 6 (according to my wk2801pro) and throttle on channel 3, but it looks like both are mapped to channel 3 somehow, nothing happens when binding some control to channel 6, but on channel 3 both, throttle and the servo, are responding.
can anyone confirm this?
Last edit: 29 Sep 2012 18:28 by flyguy.
29 Sep 2012 18:43 #1872
Yep, ch6 should be the cyclic3, the ch3 should be simply the throttle.
The 6ch heli template should do that. You only have to set the protocol and the reverses properly, and a gyro channel, if there is one, like you have on ch5...
However I don't know what is the difference between setting the reverse on the channel page or in the heli swash settings...
- flyguy
29 Sep 2012 18:55 #1873
by flyguy
i started with the 6ch heli template, but it did not work as expected, so made a new one, to figure out what's wrong.
The problem is, that both, channel 3 and 6 on the receiver side react on channel 3 from the tx and absolutely nothing happens on channel 6. this only applies for the 2601 mode. i'm pretty sure now that's some bug.
- flyguy
29 Sep 2012 19:04 #1874
by flyguy
i tested again with a new clean model and only assigned an input to channel 3. no more assignments or mixers. even with this minimal config, both, servo and throttle are reacting.
29 Sep 2012 19:04 #1875
Well, it must be a bug then, because in the tx and emulator everything seems fine...
- flyguy
29 Sep 2012 19:17 - 29 Sep 2012 20:05 #1878
by flyguy
in 2k2x01.c, build_data_pkt_2601() looks kind of different, compared to 2401 and 2801. Is there some documentation about thatprotocols somewhere?
edit:
am i getting it right? is packet[6] just channel 6 as in 2801 mode? if so, it's always zero and so is channel 5.
edit:
Last edit: 29 Sep 2012 20:05 by flyguy.
08 Oct 2012 04:00 #2039
Any news with 2601 protocol? Walkera 4G3 (RX2605A) has problems also.
Time to create page: 0.688 seconds
