- Problem Conection to pc for jumper t8sg v2.0 plus
- NiKy
22 Oct 2020 15:00 - 22 Oct 2020 17:49 #76906
by NiKy
Problem Conection to pc for jumper t8sg v2.0 plus was created by NiKy
The radio is not detected by the pc and I don't know what to do.
Could you please help me?
Thank you
Thank you
Last edit: 22 Oct 2020 17:49 by NiKy.
- propnut
22 Oct 2020 21:18 #76907
by propnut
Replied by propnut on topic Problem Conection to pc for jumper t8sg v2.0 plus
Have you put it into USB mode ??? Hold the ENTER key down and then just tap the power button. You should then see a USB symbol omn the screen. If so then plug it into the PC
- NiKy
23 Oct 2020 09:56 #76922
by NiKy
Replied by NiKy on topic Problem Conection to pc for jumper t8sg v2.0 plus
Ok, I did as you said but the pc does not detect the radio anyway
- propnut
24 Oct 2020 13:16 #76927
by propnut
Do you hear the radio making a sound when you plug the radio in WITH the USB symbol showing ? It could be that your radios drive needs formatting. Alternatively you may need to install the driver. Download and run ZADIG with the radio plugged in.
- NiKy
24 Oct 2020 16:36 - 24 Oct 2020 16:37 #76929
by NiKy
When i connect the radio with the usb symbol shown on the screen to the computer i hear nothing. I tried using Zadig but it doesn't report anything to me, it tells me no devices found.
Last edit: 24 Oct 2020 16:37 by NiKy.
- propnut
24 Oct 2020 18:40 #76930
by propnut
Have you tried a different PC ? Also what operating system are you using ?? NOT MAC I hope
- Gerry
- Bbrad
25 Oct 2020 01:25 #76931
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Problem Conection to pc for jumper t8sg v2.0 plus
Have you tried a different usb cable?
Time to create page: 0.063 seconds
