Problem Conection to pc for jumper t8sg v2.0 plus
22 Oct 2020 15:00 - 22 Oct 2020 17:49 #76906 by NiKy
The radio is not detected by the pc and I don't know what to do.
Could you please help me?
Thank you
Last edit: 22 Oct 2020 17:49 by NiKy.
22 Oct 2020 21:18 #76907 by propnut
Have you put it into USB mode ??? Hold the ENTER key down and then just tap the power button. You should then see a USB symbol omn the screen. If so then plug it into the PC
23 Oct 2020 09:56 #76922 by NiKy
Ok, I did as you said but the pc does not detect the radio anyway :(
24 Oct 2020 13:16 #76927 by propnut
Do you hear the radio making a sound when you plug the radio in WITH the USB symbol showing ? It could be that your radios drive needs formatting. Alternatively you may need to install the driver. Download and run ZADIG with the radio plugged in.
24 Oct 2020 16:36 - 24 Oct 2020 16:37 #76929 by NiKy
When i connect the radio with the usb symbol shown on the screen to the computer i hear nothing. I tried using Zadig but it doesn't report anything to me, it tells me no devices found.
Last edit: 24 Oct 2020 16:37 by NiKy.
24 Oct 2020 18:40 #76930 by propnut
Have you tried a different PC ? Also what operating system are you using ?? NOT MAC I hope
25 Oct 2020 01:25 #76931 by Gerry
Have you tried a different usb cable?
FFS (Forever Fixing Stuff)
Time to create page: 0.045 seconds
