Don't work on devo 12 S ?
- pilatus pc6
25 Sep 2012 09:25 #1813
by pilatus pc6
Don't work on devo 12 S ? was created by pilatus pc6
Hi, I just buy the all new devo 12S and I try to hack it with the deviation soft, but i will try each version and each time i have black screen, the power switch cant cut off the radio, I need to remove the batt !
his this a compatibility problem , Deviation is just for 6/6S and 8/8S ?
If yes, are you working on a 12/12S soft ? Because I really would like to experience the great fonction off your soft
25 Sep 2012 09:56 #1814
Replied by FDR on topic Don't work on devo 12 S ?
So far only 6/6S and 8/8S are supported...
...development for the 12 has just begun:
www.deviationtx.com/forum/7-development/893-devo-12
However it doesn't neccessarily means the DEVO 12 is the next...
- kohansey
25 Sep 2012 14:27 - 25 Sep 2012 14:29 #1819
by kohansey
Replied by kohansey on topic Don't work on devo 12 S ?
I am having hard time finding out what LCD controller chip used in this transmitter. I was wondering if you could take off the back of your Devo12s and take some pictures of the chips on the circuit board. I am mainly concerned with the chip that is right above the LCD ribbon connector. Hopefully the marking aren't scrapped off like they are on mine.
Last edit: 25 Sep 2012 14:29 by kohansey.
- pilatus pc6
26 Sep 2012 20:28 #1836
by pilatus pc6
Replied by pilatus pc6 on topic Don't work on devo 12 S ?
Can you post me a pics off your where is the chip, this must help me to do it for you ! I know nothing in electronics
27 Sep 2012 03:59 - 27 Sep 2012 03:59 #1837
Replied by vlad_vy on topic Don't work on devo 12 S ?
Last edit: 27 Sep 2012 03:59 by vlad_vy.
Time to create page: 0.204 seconds
- Don't work on devo 12 S ?
