Binding with Phoenix RC
01 Oct 2012 12:52 - 01 Oct 2012 12:53 #1903 by digitracer
Binding with Phoenix RC was created by digitracer
having just installed Deviation on my Devo6 I am wondering how to connect to Phoenix RC. With the devo 6 firmware it was just a matter of turning the Devo on. With Deviation I don't get it recognized by Phoenix. Is there anything special that I've got to do different now?
Additionally I wanted to thank all who have made this fantastic Deviation firmware come true!
Niels
Last edit: 01 Oct 2012 12:53 by digitracer.
01 Oct 2012 13:03 #1904 by PhracturedBlue
Replied by PhracturedBlue on topic Binding with Phoenix RC
Yes, Deviation is quite different in this regards.
You need to create a 'Simulator' model which uses PPM as the protocol. You probably want to use a simple config (like 6ch Airplane).
After you've created ans saved your Simulator model, you can reboot with this model, or Load it, or press 'Re-bind' to PPM mode.
01 Oct 2012 14:04 - 01 Oct 2012 14:09 #1908 by digitracer
Replied by digitracer on topic Binding with Phoenix RC
Yep, PPM does the trick! I went all the way down to Flysky only. Couldn't find the PPM protocol listed in the manual.
Thanks and greets,
Niels
Last edit: 01 Oct 2012 14:09 by digitracer.
Time to create page: 0.697 seconds
