- What is the "Buttons" page (under Configuration)?
- Eriskio
09 Oct 2012 20:35 #2133
by Eriskio
What is the "Buttons" page (under Configuration)? was created by Eriskio
I received today my Devo 8S (waiting the firmware form my former Devo 12
). I just installed the Deviation 1.1.2
Anything seems to work but I doesn't understand what the page "Buttons" is for.
Anywhere you touch the screen in that page (also on arrow on the top, to move to another page) the label toggles from "Touch to Lock/touch to Unlock".
Someone can explain how it should work and why?
Thank you
Thank you
- flint723
09 Oct 2012 21:17 - 09 Oct 2012 21:28 #2134
by flint723
Replied by flint723 on topic What is the "Buttons" page (under Configuration)?
edit: look below for the right answer ;o
Last edit: 09 Oct 2012 21:28 by flint723.
- rototophe
09 Oct 2012 21:27 - 09 Oct 2012 21:30 #2135
by rototophe
Not exactly.
That page allows you to test button functionality.
Press a button and the corresponding box on the screen will turn red.
Locking the button by touching the screen allows you to cut output of the buttons while you do the tests.
If you test the button "exit" without locking the buttons then you will exit the "Buttons" screen. However if the buttons are locked you can test you "exit" button without exiting the "Buttons" screen. Same goes for trims and so on for the currently loaded model.
Replied by rototophe on topic What is the "Buttons" page (under Configuration)?
flint723 wrote: From what i understand, that page is for enabling and disabling the physical buttons on the Tx. The bottom two rows are the 6 buttons on either side of the screen. The top 3 rows are the 6 trim sliders, so if you want to disable them so you don't accidentally hit a trim switch, you can. However you can't check or uncheck the boxes, so I just leave that page alone.
Not exactly.
Last edit: 09 Oct 2012 21:30 by rototophe.
- Eriskio
10 Oct 2012 06:18 #2141
by Eriskio
Replied by Eriskio on topic What is the "Buttons" page (under Configuration)?
Ok, thank you.
Time to create page: 0.675 seconds
