Problem with send reply at forum
14 Oct 2012 06:10 - 14 Oct 2012 06:17 #2209
Problem with send reply at forum was created by vlad_vy
If I send reply, forum freezed and over some time I get '502 Bad Gateway' message. If I return to forum, I can see my reply. It take place last two days, from different computers.
If I edit my message, I can save message without problems.
I only have such problem?
Last edit: 14 Oct 2012 06:17 by vlad_vy.
14 Oct 2012 06:14 - 14 Oct 2012 09:04 #2210
Replied by vlad_vy on topic Problem with send reply at forum
Firefox test = the same result '502 Bad Gateway'.
Windows XP, Internet Explorer 8, Firefox v16.0.1.
Last edit: 14 Oct 2012 09:04 by vlad_vy.
14 Oct 2012 08:55 #2211
Replied by rbe2012 on topic Problem with send reply at forum
Also with Firefox - if this message appears, everything is fine (Firefox 15.0.1, Win7-64bit).
14 Oct 2012 08:56 #2212
Message is there, but got the same error message
14 Oct 2012 09:49 - 14 Oct 2012 09:49 #2214
Replied by FDR on topic Problem with send reply at forum
Yep, it's there since the downtime on thursday...
EDIT: But this time it was OK
Last edit: 14 Oct 2012 09:49 by FDR.
14 Oct 2012 09:58 - 14 Oct 2012 10:01 #2215
Check 1 = 502 Bad Gateway
Last edit: 14 Oct 2012 10:01 by vlad_vy.
14 Oct 2012 12:33 #2218
Replied by PhracturedBlue on topic Problem with send reply at forum
Ok. I noticed it too, but thought it was because I was using HTTPS. I'll look into it.
- marc
14 Oct 2012 15:49 #2228
by marc
Replied by marc on topic Problem with send reply at forum
I also had this error. And I think the error caused the last topic in the "config files" theme which has no author and no date. The subject is the same as in my original contribution
Could you please erase it?
Many thanks to the authors and contributors if this very interesting firmware project!
Marc
Marc
14 Oct 2012 17:12 - 14 Oct 2012 17:13 #2234
Testing. Hopefully the issue is now fixed.
It appears the issue was related to the mailing system. I'm not sure it is fixed permanently, but we'll see. Let me know if you see a recurrence or any other issues
Last edit: 14 Oct 2012 17:13 by PhracturedBlue.
14 Oct 2012 17:13 - 14 Oct 2012 17:14 #2235
Check 2 = OK!
Last edit: 14 Oct 2012 17:14 by vlad_vy.
07 Dec 2012 13:50 - 07 Dec 2012 13:52 #3753
Once again, the same problem.
Last edit: 07 Dec 2012 13:52 by vlad_vy.
Time to create page: 0.998 seconds
- Problem with send reply at forum
