Problem with model icons in devo6. / SOLVED /
26 Nov 2012 18:46 - 27 Nov 2012 13:31 #3247 by Ecoalfa
I Update my devo6 to deviation firmware and all its ok, work very well and fast, but when i download icons and copy to modelico folder in tx don´t show the image at screen, the name show but pic no..
help please :P
Last edit: 27 Nov 2012 13:31 by Ecoalfa.
26 Nov 2012 18:50 - 26 Nov 2012 18:51 #3248 by domcars0
Replied by domcars0 on topic Problem with model icons in devo6.
Are you sure that your icon is at the good format ?
Please read :
www.deviationtx.com/forum/model-icons/87...r-making-model-icons
Last edit: 26 Nov 2012 18:51 by domcars0.
26 Nov 2012 18:57 - 26 Nov 2012 19:22 #3249 by FDR
Replied by FDR on topic Problem with model icons in devo6.
Not necessarily a problem: very few image viewers can show this image format.
EDIT: I think I misunderstood. I thought you don't see them in an explorer folder... :blush:
The tx of course should show it, if it is in the correct 16bit RGB565 or ARGB1555 format...
Last edit: 26 Nov 2012 19:22 by FDR.
26 Nov 2012 19:18 #3250 by PhracturedBlue
Replied by PhracturedBlue on topic Problem with model icons in devo6.
please post or link to an example bmp so we can take a look
26 Nov 2012 19:32 #3251 by Ecoalfa
Replied by Ecoalfa on topic Problem with model icons in devo6.
Thanks for reply :)
I download the icons from this forum, i try with some of this for example:
www.deviationtx.com/forum/model-icons/1068-walkera-genius-cp-v2
www.deviationtx.com/forum/model-icons/1052-v120d02s
Download the icon, turn on the tx wit enter button, make usb drive in pc and put the icon in modelico folder.
When i go to model menu, model name ico, show the new icon name but don´t show the image, I load anyway with no preview and don´t show it in main screen. assigned to the site icon is empty?
Sorry for my english :unsure:
27 Nov 2012 10:30 - 27 Nov 2012 13:35 #3275 by Ecoalfa
Solved! with new ver 2.0 :)
Last edit: 27 Nov 2012 13:35 by Ecoalfa.
27 Nov 2012 10:38 #3276 by FDR
I've just tried the same GCP_V2 file in the emulator, and it worked.
Please post your downloaded bmp file here!
27 Nov 2012 10:40 - 27 Nov 2012 10:41 #3277 by Ecoalfa
Last edit: 27 Nov 2012 10:41 by Ecoalfa.
27 Nov 2012 10:47 - 27 Nov 2012 10:59 #3278 by FDR
Your attached bmp does work too...
Maybe something went wrong, when you copied it to the USB filesystem.
Probably it was writed only to the cache, and not flushed.
Did you safely remove the USB drive after copying the file but before restarting the tx?
Last edit: 27 Nov 2012 10:59 by FDR. Reason: typo
27 Nov 2012 10:56 - 27 Nov 2012 10:57 #3279 by Ecoalfa
Yes, I remove usb drive security mode from pc and restart the tx :(
When i copy the bmp to tx the size in tx drive is correct.
Last edit: 27 Nov 2012 10:57 by Ecoalfa.
27 Nov 2012 11:01 #3280 by FDR
OK, post the actual bmp file from your tx (if the previous one was from your PC).
27 Nov 2012 11:14 #3281 by Ecoalfa
ok from tx.
27 Nov 2012 11:25 #3283 by FDR
Strange. It works in the emulator too.
What fw version do you use?
27 Nov 2012 11:32 #3284 by Ecoalfa
27 Nov 2012 11:52 #3285 by FDR
One more comment: the file name have to comply with the 8.3 naming convention, so it actually should not be "GCP_V2_2012-11-27.bmp".
27 Nov 2012 13:30 #3289 by Ecoalfa
Hello!
With the new version 2.0 all its ok! :woohoo:
Thanks for all! :P
27 Nov 2012 13:56 #3293 by vlad_vy
Replied by vlad_vy on topic Problem with model icons in devo6.
FDR wrote: One more comment: the file name have to comply with the 8.3 naming convention, so it actually should not be "GCP_V2_2012-11-27.bmp".
If topic already contain file with exactly the same name, forum will add current date to file name, for a start.
Time to create page: 0.210 seconds
