V tail mixing
06 Jan 2013 08:33 #4721 by N4JC
V tail mixing was created by N4JC
Thinking about V tail, anyone have an example of how to do V tail mixing with deViation? This would be a good opportunity for me to learn how to program this. Can anyone point me in the right direction?
  • rbe2012
  • rbe2012's Avatar
06 Jan 2013 09:11 #4723 by rbe2012
Replied by rbe2012 on topic V tail mixing
Planes are new to me since Walkera does not produce them and I can fly them only since deViation.
V tail mixing is not so complicated (if i have unterstood this correct). You have to make two virtual channels bounded to the aile and elev channels of your rx. As inputs you use a complex mixer where on the first the elev is input for both with the same sign and scale (I used about 60%) and the second is added based on the aile stick, for the first virtual channel with a scale of say +60% and on the second with -60%.
In the result both flaps move identically up or down on elev and contrary on aile.
You can see the mixer in my model.ini.
11 Jan 2013 04:32 #4914 by N4JC
Replied by N4JC on topic V tail mixing
Thank you rbe2012, I'll experiment with this.
11 Jan 2013 11:15 - 11 Jan 2013 11:17 #4922 by phoxache
Replied by phoxache on topic V tail mixing
I'm not running DeViation at the moment but just in case it helps...
I fly a V-Tail Durafly Zephyr with a Devo 7.
From memory, I went:
MODEL > TYPE = AERO > WING = V-TAIL.
Then the rudder and elev rx slots are for your L-TAIL and R-TAIL.
phox.
Last edit: 11 Jan 2013 11:17 by phoxache.
  • rbe2012
  • rbe2012's Avatar
11 Jan 2013 12:17 #4923 by rbe2012
I believe it's not so easy with deViation, but much more powerful.
Anyway, should we have a V-Tail template for the beginners? I haven't tried do make a template so I can't say how hard this will be...
12 Jan 2013 15:20 - 12 Jan 2013 15:32 #4945 by vlad_vy
Replied by vlad_vy on topic V tail mixing
My first attempt create template. Sorry, but channels automapping not works, it destroy complex mix. Channels mapping is for DEVO protocol.
Airplane with V-Tail template
File Attachment:
File Name: v-tail.ini
File Size:1 KB
Airplane with Elevon template
File Attachment:
File Name: elevon.ini
File Size:1 KB
Last edit: 12 Jan 2013 15:32 by vlad_vy.
15 Jan 2013 04:23 - 15 Jan 2013 05:08 #5033 by vlad_vy
Next try:
Template: Airplane with Elevon and Dual Rates (FMODE switch)
File Attachment:
File Name: elevon2.ini
File Size:1 KB
If you need change direction one of elevons, simply reverse that channel, at channel properties.
Last edit: 15 Jan 2013 05:08 by vlad_vy.
15 Jan 2013 15:21 - 15 Jan 2013 15:25 #5040 by vlad_vy
Template: Airplane with V-Tail and Dual Rate (ELEV DR switch)
File Attachment:
File Name: v-tail2.ini
File Size:1 KB
If you need change direction one of V-Tail control surface, simply reverse that channel, at channel properties.
Last edit: 15 Jan 2013 15:25 by vlad_vy.
15 Jan 2013 15:37 - 15 Jan 2013 15:37 #5041 by FDR
Replied by FDR on topic V tail mixing
Would you post these templates in the "Model Templates" forum, please?
www.deviationtx.com/forum/model-templates
Last edit: 15 Jan 2013 15:37 by FDR.
15 Jan 2013 16:43 #5042 by vlad_vy
I'm not 100% confident that templates are correct and I can't verify it by myself. But why not?
15 Jan 2013 17:20 #5044 by FDR
Users will find them easier there...
Time to create page: 0.672 seconds
