Simplified mixer's icons
22 Jan 2013 14:00 #5366 by PhracturedBlue
Replied by PhracturedBlue on topic Simplified mixer's icons
You can take a model generated in standard mode and move it to advanced mode (there may be a couple bugs at the moment doing this, but we'll get them resolved).
you cannot move the other way in general.
22 Jan 2013 14:18 #5367 by FDR
Replied by FDR on topic Simplified mixer's icons
proteus wrote: I do not understand everything about the standard mode / Advanced mode.
if I understand correctly, a model must be created in either simplified or advanced in the configuration files are not compatible, is that correct?
we can not take a model created by another user in simplified mode and advanced mode rework?
While as PB wrote, you can convert a "standard" model config into an "advanced" one, but in the rare exception of a CCPM heli it doesn't worth to do it, because the "standard" UI makes the model config too complicated...
22 Jan 2013 14:30 #5368 by FDR
proteus wrote: very good, I like a lot too. it is clearer for dual-rate
I was used to seeing the alarm clock but is also well
good job :)
I'm still not pleased with all...
- While the stopwatch is a better symbol than the alarm clock was, it looks ugly if I make it smaller, and it differs from the others with the white clockface (unfortunately even uglier if the clockface is transparent).
- I still don't like the gyro. It is a downsampled picture, and not as symbolic as the others...
- I made the switch assignment larger. While it is better, it's still not that good as some might though...
- I should redraw the spanner too...
22 Jan 2013 15:38 #5370 by domcars0
Replied by domcars0 on topic Simplified mixer's icons
Here is may be another gyro icon:
22 Jan 2013 15:53 #5371 by FDR
domcars0 wrote: Here is may be another gyro icon:
Thanks, I like it!
22 Jan 2013 15:59 #5372 by proteus
Replied by proteus on topic Simplified mixer's icons
and by the background dark orange?
I like yours, but that of domcars0 may be better :)
I personally love it as it is
22 Jan 2013 21:13 #5391 by domcars0
I think that it will be cut to have different colors version (not only yellow)
so the user can choose it according to the current 'theme' ...(but this is probably to the 'theme creator' to do that)
29 Jan 2013 12:01 #5718 by 944storm
Replied by 944storm on topic Simplified mixer's icons
I'm a newbie here and was wondering where I can download these new icons?! I really like them!
29 Jan 2013 12:17 #5719 by FDR
The released fw version doesn't use them yet.
However you can download the source files from:
bitbucket.org/PhracturedBlue/deviation
...and they are in the following folder:
/src/filesystem/devo8/media
  • rbe2012
  • rbe2012's Avatar
29 Jan 2013 12:26 #5720 by rbe2012
Replied by rbe2012 on topic Simplified mixer's icons
944storm wrote: ...download these new icons?! I really like them!
These icons are not fur use as toggle icons but for a graphical menu, which is not released yet. So they are useless unless you scale and save them together with the rest in the toggle.bmp.
30 Jun 2013 21:21 #11649 by PhracturedBlue
FDR, could you create an icon for the datalog page for the simplified GUI?
04 Jul 2013 20:25 #11906 by FDR
PhracturedBlue wrote: FDR, could you create an icon for the datalog page for the simplified GUI?
Here are two samples:
Time to create page: 0.270 seconds
