HELP
30 Jan 2013 08:13 #5771 by intarsio
HELP was created by intarsio
Hello, I have a TX DEVO 7E . I use it with BLADE Mcpx bnf,someone knows tell me if you can? Or what do I buy or do in order to obtain the binding between TX and the heli? Thank you very much RobertoM.
  • rbe2012
  • rbe2012's Avatar
30 Jan 2013 08:20 #5773 by rbe2012
Replied by rbe2012 on topic HELP
You should wait until the next release of deViation will be public (the developers have finished the functionality and are working on bug fixes now). This will support the 7e. There is a thread where you can read the actual state (beyond development).
For now you would only have to build your own firmware from the sources, but you should have some experiences with this to be successful.
So my advice: be patient for a few days and keep tracking this site, you will see the progress.
  • rbe2012
  • rbe2012's Avatar
30 Jan 2013 08:25 #5774 by rbe2012
If you want to test: I just read the first experimental build is there.
But be careful: as far as I remember you will not have a chance now to go back to the original firmware - if this build does not work for you your tx will be useless until the next updates come.
Time to create page: 0.074 seconds
