Devo 12S USB driver for Windows 8Pro x64
- giorf
05 Feb 2013 07:02 #6036
by giorf
Devo 12S USB driver for Windows 8Pro x64 was created by giorf
Windows 8Pro x64
When I plug in the supplied USB cable into my Devo 12S, my computer says "Unrecognized USB device". Where can I download the USB driver? I did install DfuSE 1.5 USB upgrade.
Also, when the USB cable is plugged in (computer to Devo 12S radio), the cable gets really warm. The first time I noticed it I unplugged the cable very fast being afraid something might burn up. I tried several different USB cables and all of them heat up. Is that normal?
- SadSack
05 Feb 2013 07:23 #6038
by SadSack
Replied by SadSack on topic Devo 12S USB driver for Windows 8Pro x64
Driver is in C:\Program Files\devention Upgrade Tools
other usb mass storage mode windows should have that one
05 Feb 2013 09:32 #6044
Replied by rbe2012 on topic Devo 12S USB driver for Windows 8Pro x64
Did you install one of the experimental deViation builds or do you have the stock Walkera firmware? In the second case the USB port is only used for flashing - it does not present a mass storage device (this can only deViation with its integrated USB filesystem).
Time to create page: 0.322 seconds
- Devo 12S USB driver for Windows 8Pro x64
