CCPM?
08 Mar 2013 15:42 #7531 by SQRTneg2
CCPM? was created by SQRTneg2
How do you set up a FB heli? There is a Cyclic1, 2, and 3 curve, are these used? There are no settings under these. Am I missing something?
Abandoned WK2801Pro user
08 Mar 2013 16:00 - 08 Mar 2013 16:04 #7532 by FDR
Replied by FDR on topic CCPM?
We use 3 virtual channels (under the real ones) to prepare the values for the mixing.
(EDIT: The Cyclic 1, 2, 3 are the outputs of the mixing, they go directly to the channels...)
Load the "6Ch Helicopter" template, and look how it does...
Last edit: 08 Mar 2013 16:04 by FDR.
08 Mar 2013 18:01 #7534 by domcars0
Replied by domcars0 on topic CCPM?
SQRTneg2 wrote: How do you set up a FB heli? There is a Cyclic1, 2, and 3 curve, are these used? There are no settings under these. Am I missing something?
Did you read the User Manual (from the page 26) ?
09 Mar 2013 01:19 #7545 by SQRTneg2
Replied by SQRTneg2 on topic CCPM?
P26 just has some stuff about setting alarms. Most of the page is blank.
09 Mar 2013 05:01 #7547 by stevecox
Replied by stevecox on topic CCPM?
Check you are in the correct manual?
www.deviationtx.com/user-manual
Adelaide
09 Mar 2013 14:48 #7554 by SQRTneg2
Ah, There are two manuals! I see now. Thanks!
Silly me!
04 Jul 2015 11:59 - 05 Jul 2015 08:49 #35092 by Thomas.Heiss
Replied by Thomas.Heiss on topic CCPM?
Collective / Pitch with 4 predefined pitch curves is the 3rd virtual channel "CYC-COL".
The other two virtual channels are CYC-AIL and CYC-ELEV.
To these channels the stick inputs AIL AND ELE(v) are assigned.
Expo and DualRate are to be setup on those virtual channels.
BTW: I run into the Cyclic1 and Cyclic2 wrong assignment for AIL and ELEV channels (DSMx).
Thread including link Mantis bugtracker #0000624: www.deviationtx.com/forum/6-general-disc...ngs-for-flybar#35089
Thomas
Last edit: 05 Jul 2015 08:49 by Thomas.Heiss.
Time to create page: 0.189 seconds
